[GRASS-user] Grass 7.4.0 install error
David Kodi
kodi75.waze at gmail.com
Sun Feb 4 11:40:04 PST 2018
I used the 64-bit package. There don't appear to be any cached packages
in C:\ProgramData\Package Cache if that's what you mean.
Perhaps I could try uninstalling both OSGeo4W and Grass, clean up any
remnants and attempt a re-install of Grass only.
thanks for your reply.
Kodi
David (kodi)
*Waze State Manager, Maryland*
*USA Country Manager*
On Sun, Feb 4, 2018 at 2:24 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2018-02-04 18:34 GMT+01:00 David Kodi <kodi75.waze at gmail.com>:
> > I then installed GRASS 7.4.0 independently. Running 7.4.0 produces a
> > series 0x000007b application errors - from clean_temp.exe and
> g.gisenv.exe.
> > The Error message "Process ended with non-zero return code -1073741571"
> may
> > apply, but this is a fresh installation of GRASS. Other error posts
> point
> > to vcredist packages, so I reinstalled the distribution packages without
> any
> > luck.
> I remember that I had problem with first produced binaries for G740. I
> got similar problem as you. The second build was fine. When do you
> have installed G740 using OSGeo4W exactly? 32bit or 64bit? Try to
> remove cached packages (to force downloading package again) and then
> reinstall `grass` package.
> Ma
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180204/2285cf7b/attachment.html>
