[GRASS-user] Issue with addon r.vif in MS Windows GUI installations (stand-alone v. 7.2.2 and 7.0.5)
Dinarzarde Raheem d.raheem at nhm.ac.uk
Sat Feb 10 13:04:30 PST 2018
Hi Paulo & Helmut,
I have had a go with a Windows 10 (64 bit) machine with Grass version 7.0.5. I copied the r.vif patch into the location C:\Users\YourUserName\AppData\Roaming\GRASS7\addons\scripts.
I get the following error message (I tried with the existing installation, uninstalled this and then tried again after re-installing grass). Would it make sense to wait until the server makes the new version of r.vif available through the g.extension option and try again?
Dinarzarde
------error message-------
(Sat Feb 10 21:46:00 2018)
r.vif maps=2011_01_precip at climate_1970_2012,2011_02_precip at climate_1970_2012,2011_03_precip at climate_1970_2012,2011_04_precip at climate_1970_2012,2011_05_precip at climate_1970_2012,2011_06_precip at climate_1970_2012,2011_07_precip at climate_1970_2012,2011_08_precip at climate_1970_2012,2011_09_precip at climate_1970_2012,2011_10_precip at climate_1970_2012,2011_11_precip at climate_1970_2012,2011_12_precip at climate_1970_2012 maxvif=10 file=C:\Users\draheem\Desktop\Jan 2017\results1.csv
Reading in the data ...
ERROR: Error reading reclass file for raster map <2011_01_precip at climate_1970_2012>
  File "C:\Users\draheem\AppData\Roaming\GRASS7\addons/scrip
ts/r.vif.py", line 361, in <module>
    sys.exit(main(*gs.parser()))
ts/r.vif.py", line 222, in main
    p = ReadData(IPF, n)
ts/r.vif.py", line 150, in ReadData
    quiet=True, separator="comma").rstrip('\n'))
  File "C:\Program Files\GRASS GIS
7.0.5\etc\python\grass\script\core.py", line 446, in
read_command
    return handle_errors(returncode, stdout, args, kwargs)
7.0.5\etc\python\grass\script\core.py", line 313, in
handle_errors
    returncode=returncode)
grass.exceptions.CalledModuleError: Module run None
['r.stats', '--q', '-1n', 'input=2011_01_precip at climate_1970
e_1970_2012,2011_04_precip at climate_1970_2012,2011_05_precip@
970_2012', 'separator=comma'] ended with error
Process ended with non-zero return code 1. See errors in the
(error) output.
(Sat Feb 10 21:46:02 2018) Command finished (1 sec)
________________________________________
From: grass-user [grass-user-bounces at lists.osgeo.org] on behalf of Helmut Kudrnovsky [hellik at web.de]
Sent: 10 February 2018 16:27
To: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] Issue with addon r.vif in MS Windows GUI installations (stand-alone v. 7.2.2 and 7.0.5)
>> Did you consider using cStringIO, if you need a file-object?
>> That would avoid the temporary file and thus should be more efficient
>> too. See attached diff (it is probably not necessary to remove the last
>> line break though).
>Implemented your patch, thanks.  Dinarzarde, can you test?
tested here in OSGeo4W-winGRASS:
r.vif
maps=2011_01_precip,2011_02_precip,2011_03_precip,2011_04_precip,2011_05_precip,2011_06_precip,2011_07_precip,2011_08_precip,2011_09_precip,2011_10_precip,2011_11_precip,2011_12_precip
maxvif=10 file=D:\wd\rvif\test,csv
Statistics are written to D:\wd\rvif\test,csv
VIF round 1
variable            vif  sqrtvif
2011_01_precip     6.86     2.62
2011_02_precip     2.77     1.66
2011_03_precip    33.17     5.76
2011_04_precip    10.81     3.29
2011_05_precip     4.82     2.20
2011_06_precip     2.72     1.65
2011_07_precip     1.44     1.20
2011_08_precip    10.04     3.17
2011_09_precip     3.16     1.78
2011_10_precip     2.50     1.58
2011_11_precip    16.71     4.09
2011_12_precip    50.81     7.13
VIF round 2
2011_01_precip     6.74     2.60
2011_02_precip     2.54     1.59
2011_03_precip    18.23     4.27
2011_04_precip     8.99     3.00
2011_05_precip     4.72     2.17
2011_06_precip     2.69     1.64
2011_07_precip     1.40     1.18
2011_08_precip     9.11     3.02
2011_09_precip     3.08     1.75
2011_10_precip     2.42     1.55
2011_11_precip    16.20     4.03
VIF round 3
2011_01_precip     5.63     2.37
2011_02_precip     2.14     1.46
2011_04_precip     5.71     2.39
2011_05_precip     4.63     2.15
2011_06_precip     2.52     1.59
2011_07_precip     1.33     1.15
2011_08_precip     9.01     3.00
2011_10_precip     2.14     1.46
2011_11_precip    10.42     3.23
VIF round 4
2011_01_precip     5.53     2.35
2011_02_precip     2.13     1.46
2011_04_precip     3.09     1.76
2011_05_precip     4.10     2.03
2011_07_precip     1.24     1.11
2011_08_precip     4.26     2.06
2011_09_precip     3.01     1.74
/n
selected variables are:
2011_01_precip, 2011_02_precip, 2011_04_precip, 2011_05_precip,
2011_06_precip, 2011_07_precip, 2011_08_precip, 2011_09_precip,
2011_10_precip
(Sat Feb 10 17:24:14 2018) Command finished (31 sec)
to use the new version by g.extension, you have to wait until tomorrow when
the server delivers the precompiled addons for winGRASS.
or just download it manually from
https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.vif
and copy r.vif.py into
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
grass-user mailing list
https://lists.osgeo.org/mailman/listinfo/grass-user
