[GRASS-user] Issue with addon r.vif in MS Windows GUI installations (stand-alone v. 7.2.2 and 7.0.5)
Helmut Kudrnovsky
hellik at web.de
Sat Feb 10 08:27:59 PST 2018
>> Did you consider using cStringIO, if you need a file-object?
>> That would avoid the temporary file and thus should be more efficient
>> too. See attached diff (it is probably not necessary to remove the last
>> line break though).
>Implemented your patch, thanks. Dinarzarde, can you test?
tested here in OSGeo4W-winGRASS:
r.vif
maps=2011_01_precip,2011_02_precip,2011_03_precip,2011_04_precip,2011_05_precip,2011_06_precip,2011_07_precip,2011_08_precip,2011_09_precip,2011_10_precip,2011_11_precip,2011_12_precip
maxvif=10 file=D:\wd\rvif\test,csv
Reading in the data ...
Statistics are written to D:\wd\rvif\test,csv
VIF round 1
variable vif sqrtvif
2011_01_precip 6.86 2.62
2011_02_precip 2.77 1.66
2011_03_precip 33.17 5.76
2011_04_precip 10.81 3.29
2011_05_precip 4.82 2.20
2011_06_precip 2.72 1.65
2011_07_precip 1.44 1.20
2011_08_precip 10.04 3.17
2011_09_precip 3.16 1.78
2011_10_precip 2.50 1.58
2011_11_precip 16.71 4.09
2011_12_precip 50.81 7.13
VIF round 2
2011_01_precip 6.74 2.60
2011_02_precip 2.54 1.59
2011_03_precip 18.23 4.27
2011_04_precip 8.99 3.00
2011_05_precip 4.72 2.17
2011_06_precip 2.69 1.64
2011_07_precip 1.40 1.18
2011_08_precip 9.11 3.02
2011_09_precip 3.08 1.75
2011_10_precip 2.42 1.55
2011_11_precip 16.20 4.03
VIF round 3
2011_01_precip 5.63 2.37
2011_02_precip 2.14 1.46
2011_04_precip 5.71 2.39
2011_05_precip 4.63 2.15
2011_06_precip 2.52 1.59
2011_07_precip 1.33 1.15
2011_08_precip 9.01 3.00
2011_10_precip 2.14 1.46
2011_11_precip 10.42 3.23
VIF round 4
2011_01_precip 5.53 2.35
2011_02_precip 2.13 1.46
2011_04_precip 3.09 1.76
2011_05_precip 4.10 2.03
2011_07_precip 1.24 1.11
2011_08_precip 4.26 2.06
2011_09_precip 3.01 1.74
/n
selected variables are:
2011_01_precip, 2011_02_precip, 2011_04_precip, 2011_05_precip,
2011_06_precip, 2011_07_precip, 2011_08_precip, 2011_09_precip,
2011_10_precip
(Sat Feb 10 17:24:14 2018) Command finished (31 sec)
to use the new version by g.extension, you have to wait until tomorrow when
the server delivers the precompiled addons for winGRASS.
or just download it manually from
https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.vif
and copy r.vif.py into
C:\Users\YourUserName\AppData\Roaming\GRASS7\addons\scripts
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
