[GRASS-user] Issue with addon r.vif in MS Windows GUI installations (stand-alone v. 7.2.2 and 7.0.5)
Paulo van Breugel
p.vanbreugel at gmail.com
Sat Feb 10 07:36:18 PST 2018
On 2/3/18 1:33 PM, Stefan Blumentrath wrote:
> Hi Paulo and Helmut,
> Did you consider using cStringIO, if you need a file-object?
> That would avoid the temporary file and thus should be more efficient
> too. See attached diff (it is probably not necessary to remove the
> last line break though).
Implemented your patch, thanks. Dinarzarde, can you test?
> Just a suggestion.
> Yet, there might be even more efficient solutions. For example
> raster2numpy from pygrass…
> https://grass.osgeo.org/grass74/manuals/libpython/pygrass.raster.html#pygrass.raster.raster2numpy
> Here however, you would have to mask NULL and I am not sure how to
> (platform-independent) determine values that represent NULL in a
> raster map. This gives pointers but there are again issues with
> Windows it seems:
> https://grasswiki.osgeo.org/wiki/GRASS_Python_Scripting_Library#Interfacing_with_NumPy
> And it leaves the question how to find out if a raster is Integer or not…
> With pygrass you could do:
> from grass.pygrass import raster as r
> p = np.ma.masked_equal(r.raster2numpy(raster), np.nan)) # For floating
> point rasters on Linux
> or
> p = np.ma.masked_equal(r.raster2numpy(raster), -2147483648)) # For
> integer rasters
> Hints from experienced Python/Numpy developers would be appreciated…
> That makes me wonder if it would be worth to add/collect
> recommendations for how to solve such common operations (like e.g.
> parsing table output from grass commands) either e.g. here:
> https://trac.osgeo.org/grass/wiki/Submitting/Python
> <https://trac.osgeo.org/grass/wiki/Submitting/Python> or here:
> https://grasswiki.osgeo.org/wiki/GRASS_and_Python
> <https://grasswiki.osgeo.org/wiki/GRASS_and_Python> ?
> Cheers
> Stefan
> *From:*grass-user [mailto:grass-user-bounces at lists.osgeo.org] *On
> Behalf Of *Paulo van Breugel
> *Sent:* lørdag 3. februar 2018 09.14
> *To:* Helmut Kudrnovsky <hellik at web.de>; grass-user at lists.osgeo.org
> *Subject:* Re: [GRASS-user] Issue with addon r.vif in MS Windows GUI
> On February 2, 2018 8:52:03 PM Helmut Kudrnovsky <hellik at web.de
> <mailto:hellik at web.de>> wrote:
> >>Any idea how I can do that in such a way that it works on both Linux and
> > Windows?
> > in r.vif script I've changed the relevant lines:
> > # Get the raster values at sample points
> > fd, tmpcov = tempfile.mkstemp()
> > with open(tmpcov, "w") as text_file:
> > text_file.write(
> > gs.read_command("r.stats", flags="1n", input=raster,
> > quiet=True, separator="comma"))
> > p = np.loadtxt(tmpcov, skiprows=0, delimiter=",")
> > # Clean up
> > text_file.close()
> > os.close(fd)
> > os.remove(tmpcov)
> > if not n == "100%":
> > gs.run_command("r.mask", flags="r", quiet=True)
> > if exist_mask['fullname']:
> > gs.run_command("g.rename", raster=[mask_backup, "MASK"],
> > quiet=True)
> > return(p)
> > and tested the script in winGRASS; it seems to work in windows; not
> tested
> > on linux and mac.
> Ok, thanks Helmut, I'll see if that works in Linux too
> > best regards
> > Helmut
> > Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> > grass-user mailing list
> > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180210/7fbc21de/attachment.html>
