[GRASS-user] Cannot re-install Grass 7.2
Mira Kattwinkel
kattwinkel-mira at uni-landau.de
Fri Feb 16 06:14:40 PST 2018
Using the nightly build of QGIS did the trick.
Mira
On 16/02/18 15:11, Moritz Lennert wrote:
> On 16/02/18 15:01, Mira Kattwinkel wrote:
>> Hi,
>> qgis-plugin-grass depends on Grass 7.2, hence when I try to install it I
>> get the following message:
>> mira at mira-mint ~ $ sudo apt-get install qgis-plugin-grass
>> Reading package lists... Done
>> Building dependency tree
>> Reading state information... Done
>> Some packages could not be installed. This may mean that you have
>> requested an impossible situation or if you are using the unstable
>> distribution that some required packages have not yet been created
>> or been moved out of Incoming.
>> The following information may help to resolve the situation:
>> The following packages have unmet dependencies:
>> qgis-plugin-grass : Depends: grass722 but it is not installable
>> E: Unable to correct problems, you have held broken packages.
>> I think I cannot fix this from the QGIS side.
> You are right. This nees to be handled by the ubuntugis packagers.
> Unless you compile GRASS and QGIS on your own.
> But do you really need the plugin ? You might be able to do what you
> want using the access to GRASS GIS commands via the Processing toolbox
> in QGIS.
> Moritz
