[GRASS-user] R: R: R: R: Grass 7.4.0 install error
Aldo CLERICI
aldo.clerici at unipr.it
Sat Feb 17 04:07:34 PST 2018
Great! It works.
As regards to find the broken software, I have tenths (may be hundreds) of programs and I should need a lot of time. May be it's an old program I don't need anymore, so I'll wait for any broken software to fix it following your suggestions.
Many thanks again for your kind and very helpful interest.
Aldo Clerici
-----Messaggio originale-----
Da: grass-user [mailto:grass-user-bounces at lists.osgeo.org] Per conto di Helmut Kudrnovsky
Inviato: sabato 17 febbraio 2018 06:41
A: grass-user at lists.osgeo.org
Oggetto: Re: [GRASS-user] R: R: R: Grass 7.4.0 install error
>I tried to install GRASS7.4 in OSGeo4W but with no success.
>The search for sqlite3* gave: sqlite3.dll in C:\Windows\System32
ok, there is another SQLite in your %PATH% on that machine.
AFAIK Windows10 doesn't install it there, this must come from another software which put the dll in C:\Windows\System32.
please try following steps:
- deinstall OSGeo4W completely on that win 10 64bit machine
- rename C:\Windows\System32\sqlite3.dll to something like xxxsqlite3.dll
- as you have done before: just install the basic OSGeo4W with GDAL etc
- install GRASS 7.4.0 in OSGeo4W
and report back if that works. I think it will.
if it works, then the software which installed the dll in
C:\Windows\System32 will be broken.
just start other software which you have installed on that machine step by step and see which one is now broken.
If you have found it, move xxxsqlite3.dll to the installation directory of this program, e.g. c:\Programs\YourSoftwareBreakingGrass and rename it back to sqlite3.dll.
then also this software should work again
HTH
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
grass-user mailing list
https://lists.osgeo.org/mailman/listinfo/grass-user
