[GRASS-user] installing grass 7.4 and grass-qgis plugin under fedora 27
Markus Metz
markus.metz.giswork at gmail.com
Mon Feb 19 02:44:39 PST 2018
On Mon, Feb 19, 2018 at 10:15 AM, Laura Poggio <laura.poggio at gmail.com>
wrote:
> Dear Markus,
> thank you very much for your help.
> In the error message, I used dnf install qgis* and it was trying to
install both versions. But the same error happens with 64 bits.
> Regarding QGIS not recognising grass7.4, could it be related with this
other thread?
http://lists.osgeo.org/pipermail/grass-user/2018-February/077854.html
Apparently QGIS does not find GRASS during configuration. As of GRASS 7.4,
there is now a working grass.pc file to be used with pkg-config, e.g.
pkg-config --libs grass. This would need to be used by QGIS configuration.
Markus M
> Thanks a lot
> Laura
> On 18 February 2018 at 22:40, Markus Neteler <neteler at osgeo.org> wrote:
>> On Sun, Feb 18, 2018 at 6:24 PM, Markus Neteler <neteler at osgeo.org>
wrote:
>> > Hi Laura,
>> > Am 18.02.2018 6:14 nachm. schrieb "Laura Poggio" <
laura.poggio at gmail.com>:
>> > Dear list,
>> > I managed to install grass 74 from the repository
>> > https://copr.fedorainfracloud.org/coprs/neteler/grass74/
>> > I tried to install the qgis plugin and it seems it requires grass72:
>> > package qgis-grass-2.18.12-1.fc27.i686 requires grass(x86-32) = 7.2.1,
but
>> > none of the providers can be installed
>> > conflicting requests
>> > (I see that you try to install the 32 bit version)
>> > [there were few of these lines, but similar in content. I can paste the
>> > whole list (long) if necessary]
>> > No, it's clear like this.
>> > I tried to install the grass-qgis plugin from both the fedora
repository and
>> > https://copr.fedorainfracloud.org/coprs/neteler/QGIS-2.18-Las-Palmas/
>> > I still need to update that repo. Will try to do that tonight.
>> I have tried but QGIS (for today?) refuses to recognize GRASS GIS 7.4
>> during compilation [1]
>> No idea why...
>> Markus
>> [1]
https://copr-be.cloud.fedoraproject.org/results/neteler/QGIS-2.18-Las-Palmas/fedora-27-x86_64/00717240-qgis/builder-live.log
>> (long, 6MB)
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180219/5e6bc96b/attachment-0001.html>
