[GRASS-user] Multiple `r.proj` requests on the same raster map(s)
Nikos Alexandris
nik at nikosalexandris.net
Sun Feb 25 00:44:07 PST 2018
* Markus Neteler <neteler at osgeo.org> [2018-02-24 23:00:32 +0100]:
>On Sat, Feb 24, 2018 at 10:31 PM, Markus Metz
><markus.metz.giswork at gmail.com> wrote:
>> On Sat, Feb 24, 2018 at 10:06 PM, Nikos Alexandris <nik at nikosalexandris.net>
>>> * Markus Metz <markus.metz.giswork at gmail.com> [2018-02-24 21:39:40 +0100]:
>>>> On Sat, Feb 24, 2018 at 9:25 PM, Nikos Alexandris
>>> Looking at jobs logs, I read lots of ".gislock" lines.
>>> It might be some permission related issue. I partially operated directly
>>> (with my user-id) on many Locations.
>>> The operateor of the scheduler, has naturally, another user-id. I wonder
>>> if I should apply GRASS_SKIP_MAPSET_OWNER_CHECK=1 everywhere.
>> No, you need to run each process in a unique temporary mapset.
>Yes, only that works. Be sure to have a sufficiently long random
>string to be used as temporary mapset name.
>You can for example the outout of
>mktemp --dry-run
>and add the machine name to it (and maybe the current time stamp
>cleaned for special chars) to avoid race conditions if you use a
>shared network storage.
Thanks M1/2.
>> Once you have
>> the final result, change the current mapset with g.mapset to the common
>> mapset where final results should stored and copy the final result from the
>> temporary mapset to the current mapset (the mapset to hold the final
>> results).
>(we have processed terabytes of LST data like this :-)
Just a pseudo-example: it would suffice then to,
save current region
for loop over something
CURRENT_MAPSET=$(g.mapset -p)
# a temporary Mapset
RANDOM_STRING=$(mktemp --dry-run |cut -d"." -f2)
grass -c $RANDOM_STRING
# do something
r.mask vector=VectorMap where="Attribute='Here'" &&
g.region zoom=MASK &&
r.zonal.stats cover=covermap base=basemap method=average output=outputmap
# back to "valid" Mapset
g.mapset $CURRENT_MAPSET
g.copy raster=outputmap@${RANDOM_STRING},outputmap
r.stats -acp in=outputmap out=report
r.mask -r
sleep 1
done
restore region
>> Alternatively/additionally, don't use the script grassXY to start a GRASS
>> session, instead define the GRASS environment with custom scripts (one for
>> the GRASS version to use, one for the database/location/mapset to use). This
>> avoids race conditions on a HPC system. A unique temporary mapset for each
>> process helps to avoid all sorts of concurrent access problems.
It mostly works for me with --exec. Mostly. That is, there are missing
or empty WIND files, here and there, and .gislock related issues.
>> Markus M
>Let's expand this Wiki section a bit with our findings (I'll try to
>find my notes):
>https://grasswiki.osgeo.org/wiki/Parallel_GRASS_jobs#Cluster_and_Grid_computing
>markusN
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180225/4ef7ce0f/attachment.sig>
