[GRASS-user] r.cross doesn't work correctly.
Gra
graziaz at gmail.com
Mon Feb 26 02:19:33 PST 2018
Dear community
I use r.cross to combine and then reclassify a set of indicators.
I realised that r.cross doesn't work correctly.
I have two inputs maps with values from 1 to 3 each.
the problem is that r.category doesn't list the first combination (eg 1 to
1)
eg
r.category map=myinput at in_data
0
1 category 1; category 2
2 category 1; category 3
3 category 2; category 1
4 category 2; category 2
5 category 2; category 3
6 category 3; category 1
7 category 3; category 2
8 category 3; category 3
in reality *the first combination exists (0 is empty but I should have
there category 1; category 1)*
the problem is that I have to iterate on 700 cases and I wont check and
correct manually.
could you fix it?
thanks
Grazia
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180226/4c998ec7/attachment.html>
