[GRASS-user] python parse_command
Anna Petrášová
kratochanna at gmail.com
Mon Feb 26 06:42:33 PST 2018
When I try this:
grass.parse_key_val('n=676 s=887 e=88 w=4', sep='=')
I get:
{u'n': u'676 s=887 e=88 w=4'}
which is what you are getting. But with adding space as vsep, I get
correct results, so it should work. Are you sure you used space there?
grass.parse_key_val('n=676 s=887 e=88 w=4', sep='=', vsep=' ')
{u's': u'887', u'e': u'88', u'w': u'4', u'n': u'676'}
On Mon, Feb 26, 2018 at 9:39 AM, Jonathan Reith <reith at mundialis.de> wrote:
> Nope, still the same error
> Am 26.02.2018 um 15:35 schrieb Anna Petrášová:
>> Would
>> parse=(grass.parse_key_val, {'sep': '=', 'vsep': ' '}))
>> help?
>> On Mon, Feb 26, 2018 at 4:53 AM, Jonathan Reith <reith at mundialis.de> wrote:
>>> Ok. So now my code is:
>>> compregion = grass.parse_command("r.in.xyz", input=xyz,
>>> separator="space", flags="sg", output="bbox",parse=(grass.parse_key_val,
>>> {'sep': '='}))
>>> print(compregion)
>>> g.region(res="1", flags="p", **compregion)
>>> and the output:
>>> {u'n': u'5611999 s=5610000 e=32361999 w=32360000 b=159.04 t=206.46'}
>>> ERROR: Invalid input <n=5611999 s=5610000 e=32361999 w=32360000 b=159.04
>>> t=206.46>
>>> Traceback (most recent call last):
>>> File "grass_scripts/error_script.py", line 40, in <module>
>>> main()
>>> File "grass_scripts/error_script.py", line 38, in main
>>> File
>>> "/home/jreith/source/grass-7.4.svn/dist.x86_64-pc-linux-gnu/etc/python/grass/pygrass/modules/interface/module.py",
>>> line 648, in __call__
>>> return self.run()
>>> File
>>> line 769, in run
>>> self.wait()
>>> File
>>> line 790, in wait
>>> module=self.name, errors=stderr)
>>> grass.exceptions.CalledModuleError: Module run g.region g.region n=5611999
>>> s=5610000 e=32361999 w=32360000 b=159.04 t=206.46 res=1 -p ended with error
>>> Process ended with non-zero return code 1. See errors in the (error) output.
>>> It seems like my last error disappeared, but now I have a new one.
>>> running < g.region n=5611999 s=5610000 e=32361999 w=32360000 b=159.04
>>> t=206.46 res=1 -p > from command line in GRASS works just fine.
>>> Any help appreciated
>>> Jonathan
>>> Am 19.02.2018 um 18:49 schrieb Pietro:
>>> Thank you Anna I did not noticed the underscor...
>>> On 19 Feb 2018 4:41 p.m., "Jonathan Reith" <reith at mundialis.de> wrote:
>>> print(compregion)
>>> g.region(compregion,res="1", flags="p")
>>> you are hassling the dictionary to a region, but you have to unpack the
>>> dictionary just write:
>>> the two * unpack the dictionary.
>>> Have fun!
>>> Pietro
>>> Studentische Hilfskraft
>>> mundialis GmbH & Co. KG
>>> Firmensitz: Kölnstraße 99, 53111 Bonn
>>> Registergericht: Amtsgericht Bonn, HRA 8528
>>> vertreten durch: mundialis Verwaltungsgesellschaft mbH
>>> Geschäftsführer:
>>> Dr. rer. nat. Markus Neteler
>>> Dipl.-Geogr. Hinrich Paulsen
>>> Dipl.-Geogr. Till Adams
>>> Tel. +49 (0)228 - 38 75 80 - 80
>>> Fax. +49 (0)228 - 96 28 99 57
>>> info [at] mundialis [dot] de
>>> Internet: www.mundialis.de
> Geschäftsführer:
