[GRASS-user] python parse_command
Jonathan Reith reith at mundialis.de
Mon Feb 26 06:49:20 PST 2018
Ok, now it works. Thanks a lot. My test-file made some problems, but now
it finally works :)
Am 26.02.2018 um 15:42 schrieb Anna Petrášová:
> When I try this:
> grass.parse_key_val('n=676 s=887 e=88 w=4', sep='=')
> I get:
> {u'n': u'676 s=887 e=88 w=4'}
> which is what you are getting. But with adding space as vsep, I get
> correct results, so it should work. Are you sure you used space there?
> grass.parse_key_val('n=676 s=887 e=88 w=4', sep='=', vsep=' ')
> {u's': u'887', u'e': u'88', u'w': u'4', u'n': u'676'}
> On Mon, Feb 26, 2018 at 9:39 AM, Jonathan Reith <reith at mundialis.de> wrote:
>> Nope, still the same error
>> Am 26.02.2018 um 15:35 schrieb Anna Petrášová:
>>> Would
>>> parse=(grass.parse_key_val, {'sep': '=', 'vsep': ' '}))
>>> help?
>>> On Mon, Feb 26, 2018 at 4:53 AM, Jonathan Reith <reith at mundialis.de> wrote:
>>>> Ok. So now my code is:
>>>>     compregion = grass.parse_command("r.in.xyz", input=xyz,
>>>> separator="space", flags="sg", output="bbox",parse=(grass.parse_key_val,
>>>> {'sep': '='}))
>>>>     print(compregion)
>>>>     g.region(res="1", flags="p", **compregion)
>>>> and the output:
>>>> {u'n': u'5611999 s=5610000 e=32361999 w=32360000 b=159.04 t=206.46'}
>>>> ERROR: Invalid input <n=5611999 s=5610000 e=32361999 w=32360000 b=159.04
>>>>        t=206.46>
>>>> Traceback (most recent call last):
>>>>   File "grass_scripts/error_script.py", line 40, in <module>
>>>>     main()
>>>>   File "grass_scripts/error_script.py", line 38, in main
>>>>   File
>>>> "/home/jreith/source/grass-7.4.svn/dist.x86_64-pc-linux-gnu/etc/python/grass/pygrass/modules/interface/module.py",
>>>> line 648, in __call__
>>>>     return self.run()
>>>>   File
>>>> line 769, in run
>>>>     self.wait()
>>>>   File
>>>> line 790, in wait
>>>>     module=self.name, errors=stderr)
>>>> grass.exceptions.CalledModuleError: Module run g.region g.region n=5611999
>>>> s=5610000 e=32361999 w=32360000 b=159.04 t=206.46 res=1 -p ended with error
>>>> Process ended with non-zero return code 1. See errors in the (error) output.
>>>> It seems like my last error disappeared, but now I have a new one.
>>>> running < g.region n=5611999 s=5610000 e=32361999 w=32360000 b=159.04
>>>> t=206.46 res=1 -p > from command line in GRASS works just fine.
>>>> Any help appreciated
>>>> Jonathan
>>>> Am 19.02.2018 um 18:49 schrieb Pietro:
>>>> Thank you Anna I did not noticed the underscor...
>>>> On 19 Feb 2018 4:41 p.m., "Jonathan Reith" <reith at mundialis.de> wrote:
>>>>   print(compregion)
>>>>   g.region(compregion,res="1", flags="p")
>>>> you are hassling the dictionary to a region, but you have to unpack the
>>>> dictionary just write:
>>>> the two * unpack the dictionary.
>>>> Have fun!
>>>> Pietro
>>>> Studentische Hilfskraft
>>>> mundialis GmbH & Co. KG
>>>> Firmensitz: Kölnstraße 99, 53111 Bonn
>>>> Registergericht: Amtsgericht Bonn, HRA 8528
>>>> vertreten durch: mundialis Verwaltungsgesellschaft mbH
>>>> Geschäftsführer:
>>>> Dr. rer. nat. Markus Neteler
>>>> Dipl.-Geogr. Hinrich Paulsen
>>>> Dipl.-Geogr. Till Adams
>>>> Tel. +49 (0)228 - 38 75 80 - 80
>>>> Fax. +49 (0)228 - 96 28 99 57
>>>> info [at] mundialis [dot] de
>>>> Internet: www.mundialis.de
>> Geschäftsführer:
Geschäftsführer:
