[GRASS-user] Multiple `r.proj` requests on the same raster map(s)
Markus Metz
markus.metz.giswork at gmail.com
Tue Feb 27 00:08:03 PST 2018
On Sun, Feb 25, 2018 at 6:34 PM, Nikos Alexandris <nik at nikosalexandris.net>
wrote:
> Thanks a lot Markus.
> I didn't mean to "hide" details.
Details are not so important here, and it is easy to get lost in details.
The general workflow and design on how to run GRASS processing chains in
parallel is more important. Most important is how a "sandbox" environment
for each job is created, i.e. unique mapset, unique GISRC file, maybe also
a unique temporary directory. This "sandbox" environment must be created
outside GRASS, then start the processing in a unique mapset with e.g.
grassXY -c /path/to/unique/mapset --exec /path/to/script, and after GRASS
finished, clean up, removing the temporary mapset and any temporary data.
Therefore it does not really help if you provide a script, more helpful
would be a description on how a script is launched for parallel processing.
Markus M
> It's the lack of time for my bad
> example. I posted the "pseudo-example" to get more or less, a
> verification, about the "logic" of it.
> My intention was/is to share scripts after polishing and corrections.
> Attached is only 1 out of many. They live in a private gitlab
> repository. I have to wait before I can share.
> I could adjust and bring my custom functions to do exactly the
> "trick"/logic you explain(ed), with a unique temporary Mapset.
> Finally, I think the `.gislock` files I find, are liekely and mostly due
> to previous failed attempts. My current solution for them is to simply
> re-run my final processes after cleaning these files (either simply
> entering and exiting in the corresponding Mapsets, or forcing grass via
> -f).
> I think that filling-in the unique mapset logic, will do away with 99%
> of the troubles.
> Nikos
> Mixed authors:
>>> Just a pseudo-example: it would suffice then to,
>>> save current region
>> does not work, you should be still outside GRASS
>>> for loop over something
>>> CURRENT_MAPSET=$(g.mapset -p)
>>> # a temporary Mapset
>>> RANDOM_STRING=$(mktemp --dry-run |cut -d"." -f2)
>> now you start GRASS ...
>>> grass -c $RANDOM_STRING
>> missing is --exec
>> ... and are out of GRASS again
>> put this in a script to be called with grass -c ... --exec myscript.sh
>>> # do something
>>> r.mask vector=VectorMap where="Attribute='Here'" &&
>>> g.region zoom=MASK &&
>>> r.zonal.stats cover=covermap base=basemap method=average
>> output=outputmap
>>> # back to "valid" Mapset
>>> g.mapset $CURRENT_MAPSET
>>> g.copy raster=outputmap@${RANDOM_STRING},outputmap
>>> r.stats -acp in=outputmap out=report
>>> r.mask -r
>>> restore region
>> does not work, you should be again outside GRASS
>> All outside GRASS, try to
>> 1. create a script with commands and parameters to be executed, e.g.
myscript.sh
>> 2. create a unique name of a temporary mapset (full path), store it in
an env var, e.g. TMPMAPSET
>> 3. run grass -c $TMPMAPSET --exec myscript.sh
>> 4. remove the temporary mapset simply with rm -fr $TMPMAPSET
>>>>> Alternatively/additionally, don't use the script grassXY to start a
>>>>> session, instead define the GRASS environment with custom scripts
(one for
>>>>> the GRASS version to use, one for the database/location/mapset to
use). This
>>>>> avoids race conditions on a HPC system. A unique temporary mapset for
each
>>>>> process helps to avoid all sorts of concurrent access problems.
>>> It mostly works for me with --exec. Mostly. That is, there are missing
>>> or empty WIND files, here and there, and .gislock related issues.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180227/eae0c273/attachment.html>
