[GRASS-user] v.out.ogr not working
Markus Metz
markus.metz.giswork at gmail.com
Wed Jan 10 14:14:43 PST 2018
On Wed, Jan 10, 2018 at 5:38 PM, alassane toure <atourej at gmail.com> wrote:
> Markus,
> Here is the system response. The code goes through the process but does
not create the output file!
The first two errors make sense, you would need to use the --overwrite
flag. The last call of v.out.ogr is strange because there are no output
messages at all, even though there should be some. Can you try with GRASS
7.5?
Markus M
> On Wed, Jan 10, 2018 at 9:28 AM, alassane toure <atourej at gmail.com> wrote:
>> Thanks Markus,
>> I will try your suggestion too!
>> alassane
>> On Wed, Jan 10, 2018 at 9:25 AM, alassane toure <atourej at gmail.com>
wrote:
>>> Thanks for your response Mauricio.
>>> Ok I will try it but v.out.ogr in GUI and in python script works using
GRASS70 though!
>>> alassane
>>> On Tue, Jan 9, 2018 at 10:13 PM, Maurício Vancine <
mauricio.vancine at gmail.com> wrote:
>>>> Hi Alassane,
>>>> maybe the problem can be the name size of columns in the attribute
table.
>>>> Try with short name.
>>>> Best.
>>>> 2018-01-09 22:56 GMT-02:00 alassane toure <atourej at gmail.com>:
>>>>> Group,
>>>>> I have been spending a lot of time on this and I need help. I am
using grass72/ gdal2.2 and both my python script and grass72 are not
producing the expected output when i run v.out.ogr! v.in.ogr does work
though!
>>>>> v.out.ogr input=parcel type=area output=/home/atourej/Data/prcl.shp
>>>>> parcel has 1107 areas and program run in 0 second with no output!!
>>>>> Your insight is appreciated
>>>>> alassane
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> grass-user at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
>>>> Maurício Humberto Vancine
>>>> Ecologist - Master Candidate in Zoology
>>>> São Paulo State University (UNESP), Rio Claro, SP, Brazil
>>>> Site | Lattes | ResearchGate | GitHub | ORCID | Google citations |
Impactstory
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180110/a6c3352c/attachment.html>
