[GRASS-user] v.out.ogr not working
alassane toure
atourej at gmail.com
Wed Jan 10 14:41:44 PST 2018
Ok GRASS75 it will be. Will keep you posted!
Again thanks guys for making time for this
On Wed, Jan 10, 2018 at 5:14 PM, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Wed, Jan 10, 2018 at 5:38 PM, alassane toure <atourej at gmail.com> wrote:
> > Markus,
> > Here is the system response. The code goes through the process but does
> not create the output file!
> The first two errors make sense, you would need to use the --overwrite
> flag. The last call of v.out.ogr is strange because there are no output
> messages at all, even though there should be some. Can you try with GRASS
> 7.5?
> Markus M
> > On Wed, Jan 10, 2018 at 9:28 AM, alassane toure <atourej at gmail.com>
> wrote:
> >> Thanks Markus,
> >> I will try your suggestion too!
> >> alassane
> >> On Wed, Jan 10, 2018 at 9:25 AM, alassane toure <atourej at gmail.com>
> wrote:
> >>> Thanks for your response Mauricio.
> >>> Ok I will try it but v.out.ogr in GUI and in python script works using
> GRASS70 though!
> >>> alassane
> >>> On Tue, Jan 9, 2018 at 10:13 PM, Maurício Vancine <
> mauricio.vancine at gmail.com> wrote:
> >>>> Hi Alassane,
> >>>> maybe the problem can be the name size of columns in the attribute
> table.
> >>>> Try with short name.
> >>>> Best.
> >>>> 2018-01-09 22:56 GMT-02:00 alassane toure <atourej at gmail.com>:
> >>>>> Group,
> >>>>> I have been spending a lot of time on this and I need help. I am
> using grass72/ gdal2.2 and both my python script and grass72 are not
> producing the expected output when i run v.out.ogr! v.in.ogr does work
> though!
> >>>>> v.out.ogr input=parcel type=area output=/home/atourej/Data/prcl.shp
> >>>>> parcel has 1107 areas and program run in 0 second with no output!!
> >>>>> Your insight is appreciated
> >>>>> alassane
> >>>>> _______________________________________________
> >>>>> grass-user mailing list
> >>>>> grass-user at lists.osgeo.org
> >>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
> >>>> Maurício Humberto Vancine
> >>>> Ecologist - Master Candidate in Zoology
> >>>> São Paulo State University (UNESP), Rio Claro, SP, Brazil
> >>>> Site | Lattes | ResearchGate | GitHub | ORCID | Google citations |
> Impactstory
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180110/fee9dc1f/attachment.html>
