[GRASS-user] v.out.ogr not working
alassane toure atourej at gmail.com
Thu Jan 11 06:15:49 PST 2018
here is the error message from running the script (Grass72).  I will
install Grass75 today as i have no clue where to locate the error file and
troubleshoot.
[image: Inline image 1]
On Wed, Jan 10, 2018 at 5:41 PM, alassane toure <atourej at gmail.com> wrote:
> Ok GRASS75 it will be.  Will keep you posted!
> Again thanks guys for making time for this
> On Wed, Jan 10, 2018 at 5:14 PM, Markus Metz <
> markus.metz.giswork at gmail.com> wrote:
>> On Wed, Jan 10, 2018 at 5:38 PM, alassane toure <atourej at gmail.com>
>> wrote:
>> > Markus,
>> > Here is the system response.  The code goes through the process but
>> does not create the output file!
>> The first two errors make sense, you would need to use the --overwrite
>> flag. The last call of v.out.ogr is strange because there are no output
>> messages at all, even though there should be some. Can you try with GRASS
>> 7.5?
>> Markus M
>> > On Wed, Jan 10, 2018 at 9:28 AM, alassane toure <atourej at gmail.com>
>> wrote:
>> >> Thanks Markus,
>> >> I will try your suggestion too!
>> >> alassane
>> >> On Wed, Jan 10, 2018 at 9:25 AM, alassane toure <atourej at gmail.com>
>> wrote:
>> >>> Thanks for your response Mauricio.
>> >>> Ok I will try it but v.out.ogr in GUI and in python script works
>> using GRASS70 though!
>> >>> alassane
>> >>> On Tue, Jan 9, 2018 at 10:13 PM, Maurício Vancine <
>> mauricio.vancine at gmail.com> wrote:
>> >>>> Hi Alassane,
>> >>>> maybe the problem can be the name size of columns in the attribute
>> table.
>> >>>> Try with short name.
>> >>>> Best.
>> >>>> 2018-01-09 22:56 GMT-02:00 alassane toure <atourej at gmail.com>:
>> >>>>> Group,
>> >>>>> I have been spending a lot of time on this and I need help.  I am
>> using grass72/ gdal2.2 and both my python script and grass72 are not
>> producing the expected output when i run v.out.ogr! v.in.ogr does work
>> though!
>> >>>>> v.out.ogr input=parcel type=area output=/home/atourej/Data/prcl.shp
>> >>>>> parcel has 1107 areas and program run in 0 second with no output!!
>> >>>>> Your insight is appreciated
>> >>>>> alassane
>> >>>>> _______________________________________________
>> >>>>> grass-user mailing list
>> >>>>> grass-user at lists.osgeo.org
>> >>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
>> >>>> Maurício Humberto Vancine
>> >>>> Ecologist - Master Candidate in Zoology
>> >>>> São Paulo State University (UNESP), Rio Claro, SP, Brazil
>> >>>> Site | Lattes | ResearchGate | GitHub | ORCID | Google citations |
>> Impactstory
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180111/6be844b6/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180111/6be844b6/attachment-0001.png>
