[GRASS-user] v.out.ogr not working
alassane toure atourej at gmail.com
Thu Jan 11 09:08:20 PST 2018
Markus & Mauricio,
v.out.ogr now works under grass74.  ESRI Shapefile is not a default and its
specification is required.
v.out.ogr input=grassvector type=area format=ESRI_Shapefile
output=dir/output.shp
Thanks for your help!!!
alassane
On Thu, Jan 11, 2018 at 9:15 AM, alassane toure <atourej at gmail.com> wrote:
> here is the error message from running the script (Grass72).  I will
> install Grass75 today as i have no clue where to locate the error file and
> troubleshoot.
> [image: Inline image 1]
> On Wed, Jan 10, 2018 at 5:41 PM, alassane toure <atourej at gmail.com> wrote:
>> Ok GRASS75 it will be.  Will keep you posted!
>> Again thanks guys for making time for this
>> On Wed, Jan 10, 2018 at 5:14 PM, Markus Metz <
>> markus.metz.giswork at gmail.com> wrote:
>>> On Wed, Jan 10, 2018 at 5:38 PM, alassane toure <atourej at gmail.com>
>>> wrote:
>>> > Markus,
>>> > Here is the system response.  The code goes through the process but
>>> does not create the output file!
>>> The first two errors make sense, you would need to use the --overwrite
>>> flag. The last call of v.out.ogr is strange because there are no output
>>> messages at all, even though there should be some. Can you try with GRASS
>>> 7.5?
>>> Markus M
>>> > On Wed, Jan 10, 2018 at 9:28 AM, alassane toure <atourej at gmail.com>
>>> wrote:
>>> >> Thanks Markus,
>>> >> I will try your suggestion too!
>>> >> alassane
>>> >> On Wed, Jan 10, 2018 at 9:25 AM, alassane toure <atourej at gmail.com>
>>> wrote:
>>> >>> Thanks for your response Mauricio.
>>> >>> Ok I will try it but v.out.ogr in GUI and in python script works
>>> using GRASS70 though!
>>> >>> alassane
>>> >>> On Tue, Jan 9, 2018 at 10:13 PM, Maurício Vancine <
>>> mauricio.vancine at gmail.com> wrote:
>>> >>>> Hi Alassane,
>>> >>>> maybe the problem can be the name size of columns in the attribute
>>> table.
>>> >>>> Try with short name.
>>> >>>> Best.
>>> >>>> 2018-01-09 22:56 GMT-02:00 alassane toure <atourej at gmail.com>:
>>> >>>>> Group,
>>> >>>>> I have been spending a lot of time on this and I need help.  I am
>>> using grass72/ gdal2.2 and both my python script and grass72 are not
>>> producing the expected output when i run v.out.ogr! v.in.ogr does work
>>> though!
>>> >>>>> v.out.ogr input=parcel type=area output=/home/atourej/Data/prcl
>>> .shp
>>> >>>>> parcel has 1107 areas and program run in 0 second with no output!!
>>> >>>>> Your insight is appreciated
>>> >>>>> alassane
>>> >>>>> _______________________________________________
>>> >>>>> grass-user mailing list
>>> >>>>> grass-user at lists.osgeo.org
>>> >>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
>>> >>>> Maurício Humberto Vancine
>>> >>>> Ecologist - Master Candidate in Zoology
>>> >>>> São Paulo State University (UNESP), Rio Claro, SP, Brazil
>>> >>>> Site | Lattes | ResearchGate | GitHub | ORCID | Google citations |
>>> Impactstory
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180111/58bc27f7/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180111/58bc27f7/attachment-0001.png>
