[GRASS-user] Unable to install add-ons on fedora23
Markus Metz markus.metz.giswork at gmail.com
Mon Jan 15 12:28:38 PST 2018
On Fri, Dec 15, 2017 at 2:37 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Dec 15, 2017 at 10:04 AM, Laura Poggio <laura.poggio at gmail.com>
wrote:
> > Dear all,
> > I am having the same problem also with the F27 package from
> > coprs/neteler/grass72/. But I am not sure it is the same problem or I am
> > doing something wrong.
> > I removed grass from fedora repository, enabled the copr repository and
then
> > installed grass again from the new repository.
> There is still a bug in the SPEC file defining how the RPM package is
> generated. It is missing to add the include/ directory into the
> grass-devel package.  See also
> https://bugzilla.redhat.com/show_bug.cgi?id=1489158
> I would need some support to get the SPEC file right.
> Anyone?
I have added a working grass.spec file to trunk r72082. It works fine with
Fedora 28 and GRASS 7.4.0 (yes, none of the two is already released).
Installing addons with g.extension as standard user works now, granted that
grass-devel is installed.
The main change is that GRASS is installed into one single folder, the same
as before, but now all required components are actually in this single
folder and not moved away to different locations. Man pages and docs are in
the system's standard locations and available without starting GRASS.
Further on, the demolocation is now included in the standard installation,
and the gui is a separate package.
@MarkusN: can you test the new spec file (trunk/rpm/grass.spec) with your
copr system? Thanks!
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180115/979a41f0/attachment.html>
