[GRASS-user] Unable to install add-ons on fedora23
Markus Neteler
neteler at osgeo.org
Mon Jan 15 14:35:30 PST 2018
On Mon, Jan 15, 2018 at 9:28 PM, Markus Metz
<markus.metz.giswork at gmail.com> wrote:
> I have added a working grass.spec file to trunk r72082. It works fine with
> Fedora 28 and GRASS 7.4.0 (yes, none of the two is already released).
> Installing addons with g.extension as standard user works now, granted that
> grass-devel is installed.
> The main change is that GRASS is installed into one single folder, the same
> as before, but now all required components are actually in this single
> folder and not moved away to different locations. Man pages and docs are in
> the system's standard locations and available without starting GRASS.
> Further on, the demolocation is now included in the standard installation,
> and the gui is a separate package.
Nice!
> @MarkusN: can you test the new spec file (trunk/rpm/grass.spec) with your
> copr system? Thanks!
Sure:
https://copr.fedorainfracloud.org/coprs/neteler/grass74/
Please test!
markusN
PS: I had to fix this:
@@ -158,7 +158,7 @@
--with-netcdf=%{_bindir}/nc-config \
%endif
--with-mysql-includes=%{_includedir}/mysql \
- --with-mysql-libs=%{_libdir} \
+ --with-mysql-libs=%{_libdir}/mysql \
%if (0%{?rhel} > 6 || 0%{?fedora})
--with-postgres-includes=%{_includedir}/pgsql \
%else
otherwise it would not find mysql...
