[GRASS-user] i.atcorr with Sentinel2
Žofie Cimburová
zoficimburova at gmail.com
Wed Jan 24 00:31:51 PST 2018
On Wed, Jan 24, 2018 at 12:35 AM, Stefan Blumentrath <
Stefan.Blumentrath at nina.no> wrote:
> Hi again,
> So, I did not prioritize tests for the time being and added a first
> attempt for a diff to https://trac.osgeo.org/grass/ticket/3482
> I would be happy if someone could review…
> i.atcorr compiles fine with the changes, works for S2B and gives non-NULL
> results.
> Zofie can you test with proper S2B data?
Hi, I tested with one scene of S2B data and all bands, and the results look
good. (Not sure how to test if they're 100 % correct, but they at least
seem to make sense.)
Best,
Zofie
> Cheers
> Stefan
> *From:* Markus Metz [mailto:markus.metz.giswork at gmail.com]
> *Sent:* tirsdag 23. januar 2018 15.31
> *To:* Stefan Blumentrath <Stefan.Blumentrath at nina.no>
> *Cc:* Markus Neteler <neteler at osgeo.org>; GRASS user list <
> grass-user at lists.osgeo.org>
> *Subject:* Re: [GRASS-user] i.atcorr with Sentinel2
> On Tue, Jan 23, 2018 at 3:24 PM, Stefan Blumentrath <
> > OK, sounds doable for me ;-).
> > Will look at it tonight. Most of the other changes for Sentinel-2B are
> already in place (I hope).
> Great!
> > Not sure if I manage to add python tests as well, looks like current
> tests are more manual?
> Apparently results differ between operating systems, therefore tests won't
> work well, unless you test if the output is all NULL, in which case a fatal
> error should be produced anyway.
> Markus M
> > Cheers
> > Stefan
> > ________________________________________
> > Von: Markus Metz [markus.metz.giswork at gmail.com]
> > Gesendet: Dienstag, 23. Januar 2018 14:50
> > An: Stefan Blumentrath
> > Cc: Markus Neteler; GRASS user list
> > Betreff: Re: [GRASS-user] i.atcorr with Sentinel2
> > On Tue, Jan 23, 2018 at 2:19 PM, Stefan Blumentrath <
> Stefan.Blumentrath at nina.no<mailto:Stefan.Blumentrath at nina.no>> wrote:
> > > OK, will give it a try.
> > The first part is more important because it 1) fixes the interpolation
> to 2.5 nm steps, and 2) helps iwave.cpp to load the response values.
> > > For the second part I am not sure if I properly understood where min -
> max wavelength for each band should be printed to.
> > > Do you mean to replace
> > > # convert limits from nanometers to micrometers
> > > lowerlimit = wavelengths[0]/1000
> > > upperlimit = wavelengths[-1]/1000
> > > Or just as a screen output?
> > Just a screen output to help update the manual
> > > You did not mean band value limits, right?
> > No, e.g. in the manual is
> > Sentinel2A Coastal blue band B1 (430nm - 457nm)
> > and this range could be printed out to screen based on the actual
> response. This range can then be copied to the manual, making life a bit
> easier for the person updating the manual.
> > > Not sure I am of help/useful for fixing create_iwave.py, but I`ll do
> my best.
> > Your help is welcome!
> > Markus M
> > > Cheers
> > > Stefan
> > > From: Markus Metz [mailto:markus.metz.giswork at gmail.com<mailto:
> markus.metz.giswork at gmail.com>]
> > > Sent: tirsdag 23. januar 2018 13.02
> > > To: Stefan Blumentrath <Stefan.Blumentrath at nina.no<mailto:
> > > Cc: Markus Neteler <neteler at osgeo.org<mailto:neteler at osgeo.org>>;
> GRASS user list <grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.
> org>>
> > > Subject: Re: [GRASS-user] i.atcorr with Sentinel2
> > > On Tue, Jan 23, 2018 at 12:25 PM, Stefan Blumentrath <
> > > > No problem. Any chance I can contribute to maintenance of
> create_iwave.py?
> > > > What needs to be done? Take your latest changes into account?
> > > nodata handling should be changed. In read_input(), missing values
> should be set to zero. Then for each band, leading and trailing zeros would
> be set to -1. This helps interpolate_band() to get the correct subrange.
> > > For each band, create_iwave.py should print out the band name and the
> wavelength as min - max. Care must be taken when finding reasonable min and
> max wavelengths: find the max response, then go back while response >
> threshold to find the min wavelength. Go forward while response > threshold
> to find the max wavelength. As threshold I suggest 0.1 to eliminate noise
> in the response values.
> > > Markus M
> > > > If you think it makes sense I will try to create a patch for adding
> S2B to i.atcorr (would be a nice exercise and does not seem too complex)?
> Will open a ticket and start working on it unless you tell me different.
> > > > Cheers
> > > > Stefan
> > > > From: grass-user [mailto:grass-user-bounces at lists.osgeo.org<mailto:
> grass-user-bounces at lists.osgeo.org>] On Behalf Of Markus Metz
> > > > Sent: tirsdag 23. januar 2018 12.03
> > > > To: Markus Neteler <neteler at osgeo.org<mailto:neteler at osgeo.org>>
> > > > Cc: GRASS user list <grass-user at lists.osgeo.org<mailto:
> grass-user at lists.osgeo.org>>
> > > > On Tue, Jan 23, 2018 at 11:51 AM, Markus Neteler <
> > > > neteler at osgeo.org<mailto:neteler at osgeo.org>> wrote:
> > > > > On Tue, Jan 23, 2018 at 11:09 AM, Žofie Cimburová
> > > > zoficimburova at gmail.com<mailto:zoficimburova at gmail.com>> wrote:
> > > > > > Forgot to cc the list.
> > > > > > The CSV and the cpp template:
> > > > https://www.dropbox.com/sh/9cnhsl59kvmx4o1/AABwnEVHdxfW_
> PqrB5Xcpczda?dl=0
> > > > > Great! Would you mind to also convert the S2A table? AFAIK it got
> > > > > updated due to recalibration compared to what we currently have.
> > > > please wait a bit with creating the cpp template, create_iwave.py
> needs some maintenance
> > > > Markus M
> > > > > markusN
> > > > > _______________________________________________
> > > > > grass-user mailing list
> > > > > grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
> > > > > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180124/d93e3ee3/attachment.html>
