[GRASS-user] Switching databases for holding attributes in Grass 7.4.1
Markus Metz
markus.metz.giswork at gmail.com
Mon Jul 2 12:06:15 PDT 2018
On Mon, Jul 2, 2018 at 4:54 PM, Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> Le Mon, 2 Jul 2018 16:36:30 +0200,
> Markus Metz <markus.metz.giswork at gmail.com> a écrit :
> > On Mon, Jul 2, 2018 at 4:04 PM, Paul Shapley <p.shapley at gmail.com>
> > wrote:
> > > Hi Markus,
> > > Used 'db.connect' driver=sqlite
> > database=$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
> > > I had to delete 'database schema=grass_gis'
> > > I had to delete 'default group=postgis_reader'
> > That seems to be a bug in db.connect, apparently it is not possible to
> > reset schema and group. Can you please open a ticket?
> AFAIR, schema= and group= (i.e. without any value) should reset these
> parameters.
That means no answer to schema and group would be a reasonable default
answer in order to easily change the current connection parameters?
Markus M
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180702/47d41115/attachment.html>
