[GRASS-user] Switching databases for holding attributes in Grass 7.4.1
Moritz Lennert mlennert at club.worldonline.be
Mon Jul 2 23:09:58 PDT 2018
Am 2. Juli 2018 21:06:15 MESZ schrieb Markus Metz <markus.metz.giswork at gmail.com>:
>On Mon, Jul 2, 2018 at 4:54 PM, Moritz Lennert
><mlennert at club.worldonline.be>
>wrote:
>> Le Mon, 2 Jul 2018 16:36:30 +0200,
>> Markus Metz <markus.metz.giswork at gmail.com> a écrit :
>> > On Mon, Jul 2, 2018 at 4:04 PM, Paul Shapley <p.shapley at gmail.com>
>> > wrote:
>> > > Hi Markus,
>> > > Used 'db.connect' driver=sqlite
>> > database=$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
>> > > I had to delete 'database schema=grass_gis'
>> > > I had to delete 'default group=postgis_reader'
>> > That seems to be a bug in db.connect, apparently it is not possible
>to
>> > reset schema and group. Can you please open a ticket?
>> AFAIR, schema= and group= (i.e. without any value) should reset these
>> parameters.
>That means no answer to schema and group would be a reasonable default
>answer in order to easily change the current connection parameters?
No, should was the wrong word: does would have been better. AFAIR, explicitly setting them to no answer already did reset them.
Moritz
