[GRASS-user] Switching databases for holding attributes in Grass 7.4.1
Markus Metz markus.metz.giswork at gmail.com
Mon Jul 2 23:48:29 PDT 2018
On Tue, Jul 3, 2018 at 8:09 AM, Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> Am 2. Juli 2018 21:06:15 MESZ schrieb Markus Metz <
markus.metz.giswork at gmail.com>:
> >On Mon, Jul 2, 2018 at 4:54 PM, Moritz Lennert
> >wrote:
> >> Le Mon, 2 Jul 2018 16:36:30 +0200,
> >> Markus Metz <markus.metz.giswork at gmail.com> a écrit :
> >> > On Mon, Jul 2, 2018 at 4:04 PM, Paul Shapley <p.shapley at gmail.com>
> >> > wrote:
> >> > > Hi Markus,
> >> > > Used 'db.connect' driver=sqlite
> >> > database=$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
> >> > > I had to delete 'database schema=grass_gis'
> >> > > I had to delete 'default group=postgis_reader'
> >> > That seems to be a bug in db.connect, apparently it is not possible
> >to
> >> > reset schema and group. Can you please open a ticket?
> >> AFAIR, schema= and group= (i.e. without any value) should reset these
> >> parameters.
> >That means no answer to schema and group would be a reasonable default
> >answer in order to easily change the current connection parameters?
> No, should was the wrong word: does would have been better. AFAIR,
explicitly setting them to no answer already did reset them.
True. However, the manual says
*schema*=*name* Database schema Do not use this option if schemas are not
supported by driver/database server
Markus M
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180703/85acce78/attachment.html>
