[GRASS-user] Semi-automatic classification with GRASS modules
    Michele Zurlo
    michele.zurlo at unimi.it
    Wed Jul  4 22:38:22 PDT 2018
Hi Giuseppe try to take a look also here, if you find something that can help you
http://hdl.handle.net/2434/574065
I tried a combination of i.segment.uspo, i.segment and v.class.mlR (Grippa et al. 2017) to classify an aerial images of Alpine areas. I get low a accuracy in classification because I did the great mistake of no consider the single properties of habitat in different Alpine belts. I hope you will get better result ;-)
I use this e-mail also to make a question, during a work I tried to classify a pancromatic aerial image using an unsupervised approach. Running i.cluster it gave me an error indicating that it needs more than two classes. What I missed?
Thank you
Michele
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180705/9deaa339/attachment.html>
