[GRASS-user] Vector map re-projected; cannot be displayed in target location/mapset
Markus Neteler neteler at osgeo.org
Sat Jul 7 03:51:01 PDT 2018
On Fri, Jul 6, 2018 at 11:22 PM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
>   A vector map of water bodies was imported into its own location, then
> re-projected to a target location. When I try to display it in the monitor
> grass75 responds,
> d.vect map=water_bodies at hydrography
> WARNING: The bounding box of the map is outside the current region, nothing
>          drawn
The display region and the map region are not necessarily the same.
Did you zoom to the map?
In addition, you may want to check
v.info water_bodies at hydrography
to be sure that things are right.
Markus
