[GRASS-user] Semi-automatic classification with GRASS modules
Michele Zurlo michele.zurlo at unimi.it
Mon Jul 9 00:08:30 PDT 2018
Hi Nikos I generally use the i.segment module because I'm working in a natural context management. I know also the i.superpixels.slic but I've not tried it yet. Indeed it could be a good idea to compare the results of both modules in different kind of environments.
About the i.cluster I remember that I tried to "abuse" the module but with me it doesn't work ;-)
My need of run i.cluster was due for a little work for a public administration. My idea was to realize a small report comparing pixel and object based approach, in older aerial image classification, adding different kind of features (radiometric, texture and so on).
Thank you, I hope so too.
Michele
<signatureafterquotedtext></signatureafterquotedtext>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180709/837e139d/attachment.html>
