[GRASS-user] g.remove failure
Veronica Andreo
veroandreo at gmail.com
Tue Jul 10 12:12:53 PDT 2018
Check if you are in the mapset where the map is, otherwise you cannot
delete maps; i.e. maps can only be removed from the mapset they belong to
HTH
Vero
El mar., 10 jul. 2018 a las 20:44, Rich Shepard (<rshepard at appl-ecosys.com>)
escribió:
> g.remove -f type=vect name=huc12
> WARNING: No data base element files found
> and the map is not removed.
> But, I can display the map, use the 'query' button in the display
> monitor,
> and get the attribute information about individual hydrological units.
> Why might g.remove fail this request?
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180710/e366a40c/attachment.html>
