[GRASS-user] g.remove failure
Rich Shepard rshepard at appl-ecosys.com
Tue Jul 10 12:37:15 PDT 2018
On Tue, 10 Jul 2018, Veronica Andreo wrote:
> Check if you are in the mapset where the map is, otherwise you cannot
> delete maps; i.e. maps can only be removed from the mapset they belong to
Vero,
   Yes, that's probably the case.
Thanks,
Rich
