[GRASS-user] Vector map point deleted but still displays
Nikos Alexandris nik at nikosalexandris.net
Wed Jul 11 00:18:37 PDT 2018
* Rich Shepard <rshepard at appl-ecosys.com> [2018-07-10 15:11:32 -0700]:
>  I removed a point from a vector map but it still shows up on the display
>monitor (see attached screenshot, point #2). The attribute table no longer
>contains that row:
>cat|y|x|label
>1|45.299844|-122.353975|USGS gauge
>3|45.302761|-122.358851|Building
>  I've tried to remove this point from the display using v.edit and the
>vector editor in the GUI map display window. I've removed that features map
>from the display and re-displayed it and killed the grass session and started a
>new one, but that point #2 still shows up on the map.
>  What have I done incorrectly?
Please post (also) the exact `v.edit` command.
Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180711/6bbf2ef4/attachment.sig>
