[GRASS-user] Start in text mode: define new location with proj.4 string
Nikos Alexandris
nik at nikosalexandris.net
Wed Jul 11 09:05:51 PDT 2018
* Rich Shepard <rshepard at appl-ecosys.com> [2018-07-11 08:24:27 -0700]:
>On Wed, 11 Jul 2018, Nikos Alexandris wrote:
>>I see. Maybe we should file an enhancement ticket, to provide this option
>>through the command line too?
>Nikos,
> I don't know how common this is. This project is the first time I've had
>DEM source files in ESRI GRID (*.adf) format and this format needs the
>proj.4 string if the GUI location wizard is not used. Using the wizard from
>the command line with the -gtext option works well, so the only need for a
>new command line option is if the import will be handled by a script rather
>than manually.
By the way, the -gtext option is not relevant. It merely shows the
welcome/logo screen when launching a GRASS GIS session, then jumps back
to the command line.
GRASS GIS remembers which option you used last time. That means, `grass
-gui` will be the "default": next time you execute `grass` it will
launch the GUI.
If you change your mind and do `grass -text`, this will the "default"
for next time you execute `grass`: it will launch only a command line
GRASS GIS session.
If you do `grass -gtext` it will end up with a command line session, not
the GUI.
Please correct me if I am mistaken.
Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180711/ee1309c4/attachment.sig>
