[GRASS-user] Importing .tif
Helmut Kudrnovsky hellik at web.de
Sat Jul 14 00:59:52 PDT 2018
>gdalinfo int_43120C4404.tif -proj4 -nomd
>Driver: GTiff/GeoTIFF
>Files: int_43120C4404.tif
>       int_43120C4404.tif.ovr
>       int_43120C4404.tif.aux.xml
>Size is 865, 1739
>Coordinate System is:
>PROJCS["NAD_1983_CORS96_UTM_Zone_10N",
>    GEOGCS["GCS_NAD_1983_CORS96",
>        DATUM["NAD_1983_CORS96",
>            SPHEROID["GRS_1980",6378137,298.257222101]],
>        PRIMEM["Greenwich",0],
>        UNIT["degree",0.0174532925199433]],
>    PROJECTION["Transverse_Mercator"],
>    PARAMETER["latitude_of_origin",0],
>    PARAMETER["central_meridian",-123],
>    PARAMETER["scale_factor",0.9996],
>    PARAMETER["false_easting",500000],
>    PARAMETER["false_northing",0],
>    UNIT["metre",1,
>        AUTHORITY["EPSG","9001"]]]
>PROJ.4 string is:
>'+proj=utm +zone=10 +ellps=GRS80 +units=m +no_defs '
>Origin = (711475.000000000000000,4798302.500000000000000)
>Pixel Size = (0.500000000000000,-0.500000000000000)
>Corner Coordinates:
>Upper Left  (  711475.000, 4798302.500) (120d23'32.93"W, 43d18'28.22"N)
>Lower Left  (  711475.000, 4797433.000) (120d23'34.13"W, 43d18' 0.06"N)
>Upper Right (  711907.500, 4798302.500) (120d23'13.75"W, 43d18'27.78"N)
>Lower Right (  711907.500, 4797433.000) (120d23'14.96"W, 43d17'59.62"N)
>Center      (  711691.250, 4797867.750) (120d23'23.94"W, 43d18'13.92"N)
>Band 1 Block=128x128 Type=Byte, ColorInterp=Gray
>  Min=15.000 Max=223.000
>  Minimum=15.000, Maximum=223.000, Mean=111.348, StdDev=14.186
>  NoData Value=0
>  Overviews: 433x870, 217x435
steps here
(1) create location by georeferenced file int_43120C4404.tif
(2)
r.in.gdal input=D:\temp\LDQ-43120C4\2012_OLC_Eastern OR
TIR\Intensity\int_43120C4404.tif output=fdgdfgf
WARNING: Datum <NAD_1983_CORS96> not recognised by GRASS and no parameters
found
Importing raster map <fdgdfgf>...
the datum isn't recognized, but raster imported
see
https://epsg.io/6782
https://epsg.io/6781
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
