[GRASS-user] script option
Frank David
frank.david at geophom.fr
Sat Jul 14 03:13:26 PDT 2018
Le 13/07/2018 à 21:51, Nikos Alexandris a écrit :
> * Frank David <frank.david at geophom.fr> [2018-07-13 19:26:36 +0200]:
>> Le 11/07/2018 à 09:31, Nikos Alexandris a écrit :
>>> * Frank David <frank.david at geophom.fr> [2018-07-10 15:44:51 +0200]:
>>>> Le 10/07/2018 à 12:25, Nikos Alexandris a écrit :
>>>>> * frank <frank.david at geophom.fr> [2018-07-10 08:05:29 +0200]:
>>>>>> Hi dear grass users,
>>>>>> I'm trying to get two field name of an attribute table (ctx_map)
>>>>>> by the options of the gui. But I can access only at the first one
>>>>>> and I don't find why...??. See my code below :
>>>>>> #%option G_OPT_V_MAP
>>>>>> #% key: ctx_map
>>>>>> #% description: vector data
>>>>>> #% required : yes
>>>>>> #% guidependency:layer,ctx_wf,ctx_wtg
>>>>>> #%end
>>>>>> #%option G_OPT_V_FIELD
>>>>>> #% key:ctx_layer
>>>>>> #% guidependency:ctx_wf,ctx_wtg
>>>>>> #%end
>>>>>> #%option G_OPT_DB_COLUMN
>>>>>> #% key:ctx_wf
>>>>>> #% description: wf name
>>>>>> #% required: yes
>>>>>> #%end
>>>>>> #% key:ctx_wtg
>>>>>> #% description: wtg name
>>>>>> #% required: yes
>>>>>> #%end
>>>>>> Thank you for your help.
>>>>>> Frank
>>>>> Dear Frank,
>>>> Hello Nikos,
>>>>> if you refer to the last two "column" options,
>>>>> how do you try to access these, in the script?
>>>>> Like,
>>>>> options['ctx_wf']
>>>>> options['ctx_wtg']
>>>> Absolutely
>>>>> Also, what .xml does
>>>>> x.ScriptName --interface-description
>>>>> generate?
>>>> There is no error on compilation, and help tab display Flags and
>>>> Parameters information, like (french accent are not well encoded):
>>>> Parameters:
>>>> obj_map=name [required]
>>>> Name of vector map
>>>> MH ou WTG projet
>>>> obj_layer=string
>>>> Layer number or name
>>>> Vector features can have category values in different layers. This
>>>> number determines which layer to use. When used with direct OGR
>>>> access this is the layer name.
>>>> Default: 1
>>>> obj_name=name [required]
>>>> Nom de l'objet
>>>> *ctx_map=name [required] **
>>>> **Name of vector map **
>>>> *Contexte éolien *
>>>> **ctx_layer=string **
>>>> **Layer number or name **
>>>> **Vector features can have category values in different layers.
>>>> This number determines which layer to use. When used with direct
>>>> OGR access this is the layer name. **
>>>> **Default: 1 **
>>>> **ctx_wf=name [required] **
>>>> *Nom du parc *
>>>> **ctx_wtg=name [required] **
>>>> *Identifiant éolienne
>>> Ah, and what does `x.ScriptName --ui` return?
>>> Maybe an encoding related issue? Related entries in trac:
>>> https://trac.osgeo.org/grass/search?q=encoding+french&noquickjump=1&changeset=on&milestone=on&ticket=on&wiki=on
>>> Nikos
>> Hello Nikos,
>> x.myscript --ui just launch the gui box.
>> I have found a trick to run the script. Actually I need one field
>> from on vector table and 2 fields from an other vector table. like
>> that it works :
>> #% label: MH ou WTG projet
>> #% required : yes
>> #% guidependency: layer,obj
>> #%end
>> #% guidependency: obj
>> #%end
>> #% key: obj
>> #% description: Nom de l'objet
>> #% required: yes
>> #%end
>> #% key: ctx_map
>> #% label: Contexte éolien
>> #% required : yes
>> #% guidependency:ctx_layer,ctx_wf,ctx_wtg
>> #%end
>> #% key:ctx_layer
>> #%end
>> #% key:ctx_wf
>> #% description: Nom du parc
>> #% required: yes
>> #%end
>> #% key:ctx_wtg
>> #% description: Identifiant éolienne
>> #% required: yes
>> #%end
>> But as soon as I try to name myself the first table by Key parameter
>> like #%key : obj_map and add key name at layer (like in the second
>> part of the code) It does not work anymore... It looks like the fisrt
>> map is automatically named "map" by the gui. I don't mind but I find
>> this strange. I'm sure there is a explanation,somewhere...
>> Cheers,
>> Frank
> Perhaps there is something, and experienced developers will notice it
> fast.
> Yet, why don't you share a minimal working code? At least the interface,
> so I can try myself to compile. Even in private if you
> prefer. I am willig to help in understanding this error. So I will learn
> about it as well.
> Nikos
Hi Nikos,
You can find below the full interface script. The script is not yet
finished. It may be helps you to understand the problem ?!
I don't really understand how works the parameter guidependency and with
which key I must connect it. I did not find any doc about that.. do you
know where I can find that ?
Thanks
Frank
#!/usr/bin/python
#-*-coding:UTF-8 -*-
#%Module
#% description: Calcul de l'intervisibilité entre WTG projet et contexte
ou objets MH et WTG projet
#% keyword: display
#% keyword: raster
#% keyword: windfarm
#%End
#% required : yes
#%end
#%end
#% key: obj
#% required: yes
#%end
#% key: ctx_map
#% required : yes
#%end
#% key:ctx_layer
#%end
#% key:ctx_wf
#% required: yes
#%end
#% key:ctx_wtg
#% required: yes
#%end
#%Option
#% key: string_zvi_obj
#% type: string
#% answer : chaine{fichier}chaine[champ1]chaine[champ2]chaine
#% label: Nom des cartes ZVI des OBJETS MH ou WTG projet (Ha)
#% description : Nom des cartes ZVI : {} est remplacé par le nom du
fichier vect, [champ] est remplacé par le contenu du champ
#% required : yes
#%End
#%Option
#% key: string_zvi_ctx
#% type: string
#% label: Nom des cartes ZVI OBJETS WTG projet ou contexte (Ha)
#% required : yes
#%End
#%option
#% key: obj_haut_mini
#% type: double
#% label: Hauteur minimum (unité de la zvi)
#% description: Hauteur minimum de l'objet visé (projet ou MH)
#% required : yes
#% answer : 0
#%end
#%option
#% key: champ_visuel
#% type: integer
#% label: Champ visuel
#% description: Champ visuel maximum étudié
#% required : yes
#% answer : 50
#%end
#%option
#% key: calculs_dg
#% type: string
#% required: no
#% multiple: yes
#% options: sum,average,moyen,minimum,maximum,stddev
#% label: Calcul cumulatif des cartes delta-Gis
#% description: Calcul cumulatif des cartes delta-Gis
#% guisection: Cumul
#%end
#%option
#% key: calculs_zvifu
#% type: string
#% required: no
#% multiple: yes
#% description: Calculs cumulatif des cartes ZVT filtrées de chaque eol
ou MH
#%end
#%option
#% type: string
#% required: no
#% multiple: yes
#%end
#%option
#% key: where_obj
#% type: string
#% required: no
#% multiple: no
#% key_desc: sql_query
#% label: Condition SQL (sans WHERE) sur n'importe quel champ de la
table MH/projet
#% description: Example: hauteur=180 and (cat > 2 and cat < 5)
#% answer: cat > 0
#%end
#%option
#% key: where_ctx
#% type: string
#% required: no
#% multiple: no
table projet/contexte
#% answer: cat > 0
#%end
#%option
#% key: output
#% label: Nom des cartes de sortie (complément)
#% description: Nom des cartes de sortie
#% required : no
#%end
#%option
#% key: desc
#% label: Commentaire a integrer aux meta-données des cartes produites
#% description: Commentaire a integrer aux meta-données des cartes produites
#% required : no
#%end
#%flag
#% key: r
#% label: Forcer le résultat en degrés, sinon formaté de 0 à 100%
#% description: degrés ou pourcent du champ visuel (0 à 1)
#%end
#%flag
#% key: v
#% label: impose que l'objet de référence (MH ou WTG projet) soit
visible (sur la base de sa zvi)
#% description: par défaut, le MH/WTG n'a pas besoin d'être visible pour
comptabiliser les éoliennes du projet/contexte vues dans le champ visuel
#%end
#%flag
#% key: s
#% label: Supprimer les couches intermédiaires au niveau de l'objet
#% description: Supprimer les couches intermédiaires au niveau de l'objet
#%end
#%flag
#% key: t
#% label: Supprimer les couches intermédiaires au niveau du groupe
#% description: Supprimer les couches intermédiaires au niveau du groupe
#%end
#%flag
#% key: u
#% label: Faire un calcul général sans double comptage des ZVT contexte
#% description: Faire un calcul général sans double comptage des ZVT
contexte
#%end
#%flag
#% key: o
#% label: Autoriser à écraser les fichiers existants
#% description: Ecraser les fichiers existants
#%end
