[GRASS-user] script option
Nikos Alexandris
nik at nikosalexandris.net
Mon Jul 16 13:29:03 PDT 2018
* Frank David <frank.david at geophom.fr> [2018-07-14 12:13:26 +0200]:
>Hi Nikos,
>You can find below the full interface script. The script is not yet
>finished. It may be helps you to understand the problem ?!
>I don't really understand how works the parameter guidependency and
>with which key I must connect it. I did not find any doc about that..
>do you know where I can find that ?
Frank, I don't know this option!
The search hits I can quickly find:
- https://grass.osgeo.org/grass74/manuals/libpython/script.html?highlight=guidependency.
- https://trac.osgeo.org/grass/search?q=guidependency
It is not mentioned in
https://grass.osgeo.org/grass75/manuals/g.parser.html. I think it
should.
A couple of grass-addons use it:
grass7/db/db.join/db.join.py:46:#% guidependency: ocolumn,scolumns
grass7/vector/v.stream.network/v.stream.network.py:38:#% guidependency: layer,column
grass7/vector/v.civil/v.civil.py:72:##% guidependency: ocolumn,scolumns
grass7/vector/v.civil/v.civil.py:80:##% guidependency: ocolumn,scolumns
grass7/vector/v.gsflow.export/v.gsflow.export.py:36:#% guidependency: layer,column
grass7/vector/v.gsflow.export/v.gsflow.export.py:43:#% guidependency: layer,column
grass7/vector/v.gsflow.export/v.gsflow.export.py:50:#% guidependency: layer,column
grass7/vector/v.gsflow.export/v.gsflow.export.py:57:#% guidependency: layer,column
grass7/vector/v.gsflow.export/v.gsflow.export.py:64:#% guidependency: layer,column
grass7/vector/v.gsflow.export/v.gsflow.export.py:71:#% guidependency: layer,column
grass7/vector/v.gsflow.export/v.gsflow.export.py:78:#% guidependency: layer,column
grass7/vector/v.gsflow.export/v.gsflow.export.py:85:#% guidependency: layer,column
grass7/vector/v.gsflow.export/v.gsflow.export.py:92:#% guidependency: layer,column
grass7/vector/v.gsflow.export/v.gsflow.export.py:99:#% guidependency: layer,column
grass7/vector/v.gsflow.export/v.gsflow.export.py:106:#% guidependency: layer,column
grass7/vector/v.gsflow.gravres/v.gsflow.gravres.py:38:#% guidependency: layer,column
grass7/vector/v.gsflow.gravres/v.gsflow.gravres.py:45:#% guidependency: layer,column
grass7/vector/v.gsflow.gravres/v.gsflow.gravres.py:52:#% guidependency: layer,column
grass7/vector/v.flexure/v.flexure.py:37:#% guidependency: layer,column
grass7/vector/v.flexure/v.flexure.py:43:#% guidependency: column
grass7/vector/v.gsflow.segments/v.gsflow.segments.py:36:#% guidependency: layer,column
grass7/vector/v.gsflow.segments/v.gsflow.segments.py:43:#% guidependency: layer,column
grass7/vector/v.gsflow.reaches/v.gsflow.reaches.py:37:#% guidependency: layer,column
grass7/vector/v.gsflow.reaches/v.gsflow.reaches.py:44:#% guidependency: layer,column
grass7/vector/v.gsflow.reaches/v.gsflow.reaches.py:51:#% guidependency: layer,column
grass7/vector/v.gsflow.reaches/v.gsflow.reaches.py:58:#% guidependency: layer,column
grass7/vector/v.stream.inbasin/v.stream.inbasin.py:50:#% guidependency: layer,column
grass7/vector/v.stream.inbasin/v.stream.inbasin.py:57:#% guidependency: layer,column
grass7/vector/v.stream.inbasin/v.stream.inbasin.py:64:#% guidependency: layer,column
grass7/vector/v.gsflow.hruparams/v.gsflow.hruparams.py:37:#% guidependency: layer,column
grass7/vector/v.gsflow.hruparams/v.gsflow.hruparams.py:44:#% guidependency: layer,column
grass7/vector/v.gsflow.hruparams/v.gsflow.hruparams.py:51:#% guidependency: layer,column
grass7/gui/wxpython/wx.metadata/t.info.iso/t.info.iso.py:25:#% guidependency: input
Something new to learn.
Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180716/2c13a21d/attachment.sig>
