[GRASS-user] v.overlay with points
Laurent C. lrntct at gmail.com
Sat Jul 28 10:15:41 PDT 2018
v.what.vect is doing exactly what I was searching for.
The last module on the list ;)
Laurent
Le sam. 28 juil. 2018 à 18:04, Laurent C. <lrntct at gmail.com> a écrit :
> Hello all,
> I have two vectors maps:
> - Map A with only points
> - Map B with polygons representing continents (with a name column)
> I want to add a column in map A that contains the continent name on which
> the point is located.
> I thought of using v.overlay, but it doesn't work with points.
> Which tool should I use for that?
> Regards,
> Laurent
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180728/2adc1673/attachment.html>
