[GRASS-user] v.overlay with points
Laurent C. lrntct at gmail.com
Sat Jul 28 10:04:46 PDT 2018
Hello all,
I have two vectors maps:
- Map A with only points
- Map B with polygons representing continents (with a name column)
I want to add a column in map A that contains the continent name on which
the point is located.
I thought of using v.overlay, but it doesn't work with points.
Which tool should I use for that?
Regards,
Laurent
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180728/291b735f/attachment.html>
