[GRASS-user] r.horizon and negative tilt
Frank David
frank.david at geophom.fr
Mon Jul 30 07:55:08 PDT 2018
Hello Markus,
is it possible to add an option to evaluate the negatives hight in a
future release ? (I don't know C)
Best regards,
Frank
Le 30/07/2018 à 16:19, Markus Metz a écrit :
> On Sat, Jul 28, 2018 at 3:59 PM, Frank David <frank.david at geophom.fr
> <mailto:frank.david at geophom.fr>> wrote:
> > Dear all,
> > It seems that r.horizon in does not return negative heights. How
> it's possible in case of the given point from the calculation is done
> is located on mountain and the horizon around is below zero ??. I miss
> something may be...
> r.horizon is indeed ignoring points that are lower than the given
> point, see
> https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.horizon/main.c#L1037
> and following lines
> I agree that this behaviour is questionable
> Markus M
> > Thank you for your explanations
> > Regards
> > Frank
> > grass-user mailing list
> > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180730/69032a6a/attachment.html>
