[GRASS-user] r.horizon and negative tilt
balotti.and at gmail.com
Sun Jul 29 23:47:17 PDT 2018
Hi Frank,
just my opinion but r.horizon I suppose is targeted to solar radiation
modules and because of that returns only the line-of-sight "obstacles"
above the ground plane, where direct sunlight may be obstructed by
obstacles.
best regards,
Andrea Balotti
Il 28/07/2018 15:59, Frank David ha scritto:
> Dear all,
> It seems that r.horizon in does not return negative heights. How it's
> possible in case of the given point from the calculation is done is
> located on mountain and the horizon around is below zero ??. I miss
> something may be...
> Thank you for your explanations
> Regards
> Frank
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
