[GRASS-user] 3D raster color coding
Veronica Andreo
veroandreo at gmail.com
Fri Jun 1 00:04:55 PDT 2018
Hello,
That's probably because that palette is for integer values ranging from 0
to 360 [0]. Try with a relative one such as viridis or bcyr.
HTH,
Vero
[0] https://grass.osgeo.org/grass74/manuals/r.colors.html
El jue., 31 may. 2018 a las 3:18, Francois Chartier (<fra.chartier at gmail.com>)
escribió:
> Hi,
> I have created a 3D raster from soil properties with about 70K points,
> with a* lot of help from the mailing list i must say*.
> from the copy of the metadata of the 3d raster (below) it would confirm
> that the 3D raster worked and the grid is populated with data.
> I have copied below the r3.colors and assigned 'aspectcolr' as a trial.
> Unfortunately in the Display window nothing shows up, whether in 2D or in
> 3D view. I do not know what i am doing incorrectly.
> Once I am done and able to develop the 3D raster of the soil properties, I
> will prepare a simple step by step for developing such a raster which may
> be useful for others.
> | Layer: BHALL_May24v2 at Toronto Date: Sun May 27 16:43:46
> 2018 |
> | Mapset: Toronto Login of Creator: Francois
> Charti |
> | Location: Toronto
> | DataBase: C:\Users\Francois Chartier\Documents\grassdata
> | Title: BHALL_May24v2
> | Units: none
> | Vertical unit: units
> | Timestamp: none
> | Type of Map: raster_3d Number of Categories: 0
> | Data Type: FCELL
> | Rows: 90
> | Columns: 85
> | Depths: 307
> | Total Cells: 2348550
> | Total size: 3180868 Bytes
> | Number of tiles: 336
> | Mean tile size: 9466 Bytes
> | Tile size in memory: 30420 Bytes
> | Number of tiles in x, y and z: 6, 7, 8
> | Dimension of a tile in x, y, z: 15, 13, 39
> | Projection: UTM (zone 17)
> | N: 4870795 S: 4825715 Res: 500.88888889
> | E: 651669 W: 609204 Res: 499.58823529
> | T: 352 B: 45 Res: 1
> | Range of data: min = -8.99099445 max = 33.89262009
> | Data Source:
> | Data Description:
> | generated by v.vol.rst
> | Comments:
> | v.vol.rst input="BHMat1All_May12 at Toronto" wcolumn="cat" tension=40.
> | smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=2 wscale=1.0
> zscale=1.\ |
> | 0 elevation="BHALL_May24v2"
> (Wed May 30 21:11:59 2018) Command finished (0 sec)
> (Wed May 30 21:10:02 2018)
> r3.colors map=BHALL_May24v2 at Toronto color=aspectcolr
> Color table for raster3d map <BHALL_May24v2 at Toronto> set to 'aspectcolr'
> (Wed May 30 21:10:03 2018) Command finished (0 sec)
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180601/f5ade2ae/attachment.html>
