[GRASS-user] 3D raster color coding
Francois Chartier
fra.chartier at gmail.com
Fri Jun 1 09:54:48 PDT 2018
Thanks, I'll check it out.
On Fri, Jun 1, 2018, 03:05 Veronica Andreo, <veroandreo at gmail.com> wrote:
> Hello,
> That's probably because that palette is for integer values ranging from 0
> to 360 [0]. Try with a relative one such as viridis or bcyr.
> HTH,
> Vero
> [0] https://grass.osgeo.org/grass74/manuals/r.colors.html
> El jue., 31 may. 2018 a las 3:18, Francois Chartier (<
> fra.chartier at gmail.com>) escribió:
>> Hi,
>> I have created a 3D raster from soil properties with about 70K points,
>> with a* lot of help from the mailing list i must say*.
>> from the copy of the metadata of the 3d raster (below) it would confirm
>> that the 3D raster worked and the grid is populated with data.
>> I have copied below the r3.colors and assigned 'aspectcolr' as a
>> trial. Unfortunately in the Display window nothing shows up, whether in 2D
>> or in 3D view. I do not know what i am doing incorrectly.
>> Once I am done and able to develop the 3D raster of the soil properties,
>> I will prepare a simple step by step for developing such a raster which may
>> be useful for others.
>> | Layer: BHALL_May24v2 at Toronto Date: Sun May 27 16:43:46
>> 2018 |
>> | Mapset: Toronto Login of Creator: Francois
>> Charti |
>> | Location: Toronto
>> | DataBase: C:\Users\Francois Chartier\Documents\grassdata
>> | Title: BHALL_May24v2
>> | Units: none
>> | Vertical unit: units
>> | Timestamp: none
>> | Type of Map: raster_3d Number of Categories: 0
>> | Data Type: FCELL
>> | Rows: 90
>> | Columns: 85
>> | Depths: 307
>> | Total Cells: 2348550
>> | Total size: 3180868 Bytes
>> | Number of tiles: 336
>> | Mean tile size: 9466 Bytes
>> | Tile size in memory: 30420 Bytes
>> | Number of tiles in x, y and z: 6, 7, 8
>> | Dimension of a tile in x, y, z: 15, 13, 39
>> | Projection: UTM (zone 17)
>> | N: 4870795 S: 4825715 Res: 500.88888889
>> | E: 651669 W: 609204 Res: 499.58823529
>> | T: 352 B: 45 Res: 1
>> | Range of data: min = -8.99099445 max = 33.89262009
>> | Data Source:
>> | Data Description:
>> | generated by v.vol.rst
>> | Comments:
>> | v.vol.rst input="BHMat1All_May12 at Toronto" wcolumn="cat"
>> tension=40. \ |
>> | smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=2 wscale=1.0
>> zscale=1.\ |
>> | 0 elevation="BHALL_May24v2"
>> (Wed May 30 21:11:59 2018) Command finished (0 sec)
>> (Wed May 30 21:10:02 2018)
>> r3.colors map=BHALL_May24v2 at Toronto color=aspectcolr
>> Color table for raster3d map <BHALL_May24v2 at Toronto> set to 'aspectcolr'
>> (Wed May 30 21:10:03 2018) Command finished (0 sec)
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180601/3f67dce6/attachment-0001.html>
