[GRASS-user] 3D raster color coding
    Veronica Andreo
    veroandreo at gmail.com
    Fri Jun  1 23:33:09 PDT 2018
Try removing -r from your command (unchecking the box in the GUI).
That flag is used to remove a color palette.
Best,
Vero
El sáb., 2 jun. 2018 3:48, Francois Chartier <fra.chartier at gmail.com>
escribió:
> Hi Veronica,
> something is odd.  here are the steps - Display window is still blank and
> the 3D raster has data ranging from -8 to 34.
> Step 2 - set as viridis - according to manual this
> *result in command window*
> (Fri Jun 01 21:44:05 2018)
> r3.colors -r map=BHALL_May24v2 at Toronto color=viridis
> (Fri Jun 01 21:44:05 2018) Command finished (0 sec)
> *Display is still blank.   *
> *Data is there*
>  |   Type of Map:  raster_3d            Number of Categories: 0
>  |   Data Type:    FCELL
>  |   Rows:         90
>  |   Columns:      85
>  |   Depths:       307
>  |   Total Cells:  2348550
>  |   Total size:           3180868 Bytes
>  |   Number of tiles:      336
>  |   Mean tile size:       9466 Bytes
>  |   Tile size in memory:  30420 Bytes
>  |   Number of tiles in x, y and  z:   6, 7, 8
>  |   Dimension of a tile in x, y, z:   15, 13, 39
>  |        Projection: UTM (zone 17)
>  |            N:    4870795    S:    4825715   Res: 500.88888889
>  |            E:     651669    W:     609204   Res: 499.58823529
>  |            T:        352    B:         45   Res:     1
>  |   Range of data:   min = -8.99099445 max = 33.89262009
>  |   Data Source:
>  |   Data Description:
>  |    generated by v.vol.rst
>  |   Comments:
>  |    v.vol.rst input="BHMat1All_May12 at Toronto" wcolumn="cat" tension=40.
>  |    smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=2 wscale=1.0
> zscale=1.\   |
>  |    0 elevation="BHALL_May24v2"
> Le ven. 1 juin 2018 à 12:54, Francois Chartier <fra.chartier at gmail.com> a
> écrit :
>> Thanks, I'll check it out.
>> On Fri, Jun 1, 2018, 03:05 Veronica Andreo, <veroandreo at gmail.com> wrote:
>>> Hello,
>>> That's probably because that palette is for integer values ranging from
>>> 0 to 360 [0]. Try with a relative one such as viridis or bcyr.
>>> HTH,
>>> Vero
>>> [0] https://grass.osgeo.org/grass74/manuals/r.colors.html
>>> El jue., 31 may. 2018 a las 3:18, Francois Chartier (<
>>> fra.chartier at gmail.com>) escribió:
>>>> Hi,
>>>> I have created a 3D raster from soil properties with about 70K points,
>>>> with a* lot of help from the mailing list i must say*.
>>>> from the copy of the metadata of the 3d raster (below) it would confirm
>>>> that the 3D raster worked and the grid is populated with data.
>>>> I have copied below the r3.colors and assigned  'aspectcolr' as a
>>>> trial.  Unfortunately in the Display window nothing shows up, whether in 2D
>>>> or in 3D view.  I do not know what i am doing incorrectly.
>>>> Once I am done and able to develop the 3D raster of the soil
>>>> properties, I will prepare a simple step by step for developing such a
>>>> raster which may be useful for others.
>>>>  | Layer:    BHALL_May24v2 at Toronto          Date: Sun May 27 16:43:46
>>>> 2018    |
>>>>  | Mapset:   Toronto                        Login of Creator: Francois
>>>> Charti |
>>>>  | Location: Toronto
>>>>  | DataBase: C:\Users\Francois Chartier\Documents\grassdata
>>>>  | Title:    BHALL_May24v2
>>>>  | Units:    none
>>>>  | Vertical unit: units
>>>>  | Timestamp: none
>>>>  |   Data Type:    FCELL
>>>>  |   Rows:         90
>>>>  |   Columns:      85
>>>>  |   Depths:       307
>>>>  |            T:        352    B:         45   Res:     1
>>>>  |   Data Source:
>>>>  |   Data Description:
>>>>  |   Comments:
>>>> tension=40. \   |
>>>> zscale=1.\   |
>>>> (Wed May 30 21:11:59 2018) Command finished (0 sec)
>>>> (Wed May 30 21:10:02 2018)
>>>> r3.colors map=BHALL_May24v2 at Toronto color=aspectcolr
>>>> Color table for raster3d map <BHALL_May24v2 at Toronto> set to
>>>> 'aspectcolr'
>>>> (Wed May 30 21:10:03 2018) Command finished (0 sec)
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180602/9b3c9fc2/attachment-0001.html>
