[GRASS-user] 3D raster color coding
Francois Chartier fra.chartier at gmail.com
Sat Jun 2 06:01:46 PDT 2018
Is there any way to set the range for the color table?
On Sat, Jun 2, 2018, 02:33 Veronica Andreo, <veroandreo at gmail.com> wrote:
> Try removing -r from your command (unchecking the box in the GUI).
> That flag is used to remove a color palette.
> Best,
> Vero
> El sáb., 2 jun. 2018 3:48, Francois Chartier <fra.chartier at gmail.com>
> escribió:
>> Hi Veronica,
>> something is odd.  here are the steps - Display window is still blank and
>> the 3D raster has data ranging from -8 to 34.
>> Step 2 - set as viridis - according to manual this
>> *result in command window*
>> (Fri Jun 01 21:44:05 2018)
>> r3.colors -r map=BHALL_May24v2 at Toronto color=viridis
>> (Fri Jun 01 21:44:05 2018) Command finished (0 sec)
>> *Display is still blank.   *
>> *Data is there*
>>  |   Type of Map:  raster_3d            Number of Categories: 0
>>  |   Data Type:    FCELL
>>  |   Rows:         90
>>  |   Columns:      85
>>  |   Depths:       307
>>  |   Total Cells:  2348550
>>  |   Total size:           3180868 Bytes
>>  |   Number of tiles:      336
>>  |   Mean tile size:       9466 Bytes
>>  |   Tile size in memory:  30420 Bytes
>>  |   Number of tiles in x, y and  z:   6, 7, 8
>>  |   Dimension of a tile in x, y, z:   15, 13, 39
>>  |        Projection: UTM (zone 17)
>>  |            N:    4870795    S:    4825715   Res: 500.88888889
>>  |            E:     651669    W:     609204   Res: 499.58823529
>>  |            T:        352    B:         45   Res:     1
>>  |   Range of data:   min = -8.99099445 max = 33.89262009
>>  |   Data Source:
>>  |   Data Description:
>>  |    generated by v.vol.rst
>>  |   Comments:
>>  |    v.vol.rst input="BHMat1All_May12 at Toronto" wcolumn="cat"
>> tension=40. \   |
>>  |    smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=2 wscale=1.0
>> zscale=1.\   |
>>  |    0 elevation="BHALL_May24v2"
>> Le ven. 1 juin 2018 à 12:54, Francois Chartier <fra.chartier at gmail.com>
>> a écrit :
>>> Thanks, I'll check it out.
>>> On Fri, Jun 1, 2018, 03:05 Veronica Andreo, <veroandreo at gmail.com>
>>> wrote:
>>>> Hello,
>>>> That's probably because that palette is for integer values ranging from
>>>> 0 to 360 [0]. Try with a relative one such as viridis or bcyr.
>>>> HTH,
>>>> Vero
>>>> [0] https://grass.osgeo.org/grass74/manuals/r.colors.html
>>>> El jue., 31 may. 2018 a las 3:18, Francois Chartier (<
>>>> fra.chartier at gmail.com>) escribió:
>>>>> Hi,
>>>>> I have created a 3D raster from soil properties with about 70K points,
>>>>> with a* lot of help from the mailing list i must say*.
>>>>> from the copy of the metadata of the 3d raster (below) it would
>>>>> confirm that the 3D raster worked and the grid is populated with data.
>>>>> I have copied below the r3.colors and assigned  'aspectcolr' as a
>>>>> trial.  Unfortunately in the Display window nothing shows up, whether in 2D
>>>>> or in 3D view.  I do not know what i am doing incorrectly.
>>>>> Once I am done and able to develop the 3D raster of the soil
>>>>> properties, I will prepare a simple step by step for developing such a
>>>>> raster which may be useful for others.
>>>>>  | Layer:    BHALL_May24v2 at Toronto          Date: Sun May 27 16:43:46
>>>>> 2018    |
>>>>>  | Mapset:   Toronto                        Login of Creator: Francois
>>>>> Charti |
>>>>>  | Location: Toronto
>>>>>  | DataBase: C:\Users\Francois Chartier\Documents\grassdata
>>>>>  | Title:    BHALL_May24v2
>>>>>  | Units:    none
>>>>>  | Vertical unit: units
>>>>>  | Timestamp: none
>>>>>  |   Data Type:    FCELL
>>>>>  |   Rows:         90
>>>>>  |   Columns:      85
>>>>>  |   Depths:       307
>>>>>  |            T:        352    B:         45   Res:     1
>>>>>  |   Data Source:
>>>>>  |   Data Description:
>>>>>  |   Comments:
>>>>> tension=40. \   |
>>>>> zscale=1.\   |
>>>>> (Wed May 30 21:11:59 2018) Command finished (0 sec)
>>>>> (Wed May 30 21:10:02 2018)
>>>>> r3.colors map=BHALL_May24v2 at Toronto color=aspectcolr
>>>>> Color table for raster3d map <BHALL_May24v2 at Toronto> set to
>>>>> 'aspectcolr'
>>>>> (Wed May 30 21:10:03 2018) Command finished (0 sec)
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> grass-user at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180602/e3fb761f/attachment-0001.html>
