[GRASS-user] 3D raster color coding
Francois Chartier fra.chartier at gmail.com
Sat Jun 2 10:51:58 PDT 2018
i removed the 'r' and used elevation and bcyr as the color tables, see
below.  Display window is blank.
to recap the steps:
1 - i selected the Mapset  and also tried Map that corresponds to the 3d
raster
2 - then in Define tab, i only choose the Name of Color Table: bcyr, i have
not selected anything else,
3 - then i just Run.
(Sat Jun 02 13:45:02 2018)
r3.colors map=BHALL_May24v2 at Toronto color=elevation
Color table for raster3d map <BHALL_May24v2 at Toronto> set to 'elevation'
(Sat Jun 02 13:45:02 2018) Command finished (0 sec)
(Sat Jun 02 13:46:14 2018)
r3.colors map=BHALL_May24v2 at Toronto color=bcyr
Color table for raster3d map <BHALL_May24v2 at Toronto> set to 'bcyr'
(Sat Jun 02 13:46:15 2018) Command finished (0 sec)
Le sam. 2 juin 2018 à 09:01, Francois Chartier <fra.chartier at gmail.com> a
écrit :
> Is there any way to set the range for the color table?
> On Sat, Jun 2, 2018, 02:33 Veronica Andreo, <veroandreo at gmail.com> wrote:
>> Try removing -r from your command (unchecking the box in the GUI).
>> That flag is used to remove a color palette.
>> Best,
>> Vero
>> El sáb., 2 jun. 2018 3:48, Francois Chartier <fra.chartier at gmail.com>
>> escribió:
>>> Hi Veronica,
>>> something is odd.  here are the steps - Display window is still blank
>>> and the 3D raster has data ranging from -8 to 34.
>>> Step 2 - set as viridis - according to manual this
>>> *result in command window*
>>> (Fri Jun 01 21:44:05 2018)
>>> r3.colors -r map=BHALL_May24v2 at Toronto color=viridis
>>> (Fri Jun 01 21:44:05 2018) Command finished (0 sec)
>>> *Display is still blank.   *
>>> *Data is there*
>>>  |   Type of Map:  raster_3d            Number of Categories: 0
>>>  |   Data Type:    FCELL
>>>  |   Rows:         90
>>>  |   Columns:      85
>>>  |   Depths:       307
>>>  |   Total Cells:  2348550
>>>  |   Total size:           3180868 Bytes
>>>  |   Number of tiles:      336
>>>  |   Mean tile size:       9466 Bytes
>>>  |   Tile size in memory:  30420 Bytes
>>>  |   Number of tiles in x, y and  z:   6, 7, 8
>>>  |   Dimension of a tile in x, y, z:   15, 13, 39
>>>  |        Projection: UTM (zone 17)
>>>  |            N:    4870795    S:    4825715   Res: 500.88888889
>>>  |            E:     651669    W:     609204   Res: 499.58823529
>>>  |            T:        352    B:         45   Res:     1
>>>  |   Range of data:   min = -8.99099445 max = 33.89262009
>>>  |   Data Source:
>>>  |   Data Description:
>>>  |    generated by v.vol.rst
>>>  |   Comments:
>>>  |    v.vol.rst input="BHMat1All_May12 at Toronto" wcolumn="cat"
>>> tension=40. \   |
>>>  |    smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=2 wscale=1.0
>>> zscale=1.\   |
>>>  |    0 elevation="BHALL_May24v2"
>>> Le ven. 1 juin 2018 à 12:54, Francois Chartier <fra.chartier at gmail.com>
>>> a écrit :
>>>> Thanks, I'll check it out.
>>>> On Fri, Jun 1, 2018, 03:05 Veronica Andreo, <veroandreo at gmail.com>
>>>> wrote:
>>>>> Hello,
>>>>> That's probably because that palette is for integer values ranging
>>>>> from 0 to 360 [0]. Try with a relative one such as viridis or bcyr.
>>>>> HTH,
>>>>> Vero
>>>>> [0] https://grass.osgeo.org/grass74/manuals/r.colors.html
>>>>> El jue., 31 may. 2018 a las 3:18, Francois Chartier (<
>>>>> fra.chartier at gmail.com>) escribió:
>>>>>> Hi,
>>>>>> I have created a 3D raster from soil properties with about 70K
>>>>>> points, with a* lot of help from the mailing list i must say*.
>>>>>> from the copy of the metadata of the 3d raster (below) it would
>>>>>> confirm that the 3D raster worked and the grid is populated with data.
>>>>>> I have copied below the r3.colors and assigned  'aspectcolr' as a
>>>>>> trial.  Unfortunately in the Display window nothing shows up, whether in 2D
>>>>>> or in 3D view.  I do not know what i am doing incorrectly.
>>>>>> Once I am done and able to develop the 3D raster of the soil
>>>>>> properties, I will prepare a simple step by step for developing such a
>>>>>> raster which may be useful for others.
>>>>>>  | Layer:    BHALL_May24v2 at Toronto          Date: Sun May 27
>>>>>> 16:43:46 2018    |
>>>>>>  | Mapset:   Toronto                        Login of Creator:
>>>>>> Francois Charti |
>>>>>>  | Location: Toronto
>>>>>>  | DataBase: C:\Users\Francois Chartier\Documents\grassdata
>>>>>>  | Title:    BHALL_May24v2
>>>>>>  | Units:    none
>>>>>>  | Vertical unit: units
>>>>>>  | Timestamp: none
>>>>>>  |   Data Type:    FCELL
>>>>>>  |   Rows:         90
>>>>>>  |   Columns:      85
>>>>>>  |   Depths:       307
>>>>>>  |            T:        352    B:         45   Res:     1
>>>>>>  |   Data Source:
>>>>>>  |   Data Description:
>>>>>>  |   Comments:
>>>>>> tension=40. \   |
>>>>>> zscale=1.\   |
>>>>>> (Wed May 30 21:11:59 2018) Command finished (0 sec)
>>>>>> (Wed May 30 21:10:02 2018)
>>>>>> r3.colors map=BHALL_May24v2 at Toronto color=aspectcolr
>>>>>> 'aspectcolr'
>>>>>> (Wed May 30 21:10:03 2018) Command finished (0 sec)
>>>>>> _______________________________________________
>>>>>> grass-user mailing list
>>>>>> grass-user at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180602/5075a0a2/attachment-0001.html>
