[GRASS-user] GRASS GIS virtual raster data sets
Nikos Alexandris
nik at nikosalexandris.net
Fri Jun 1 01:40:08 PDT 2018
Essentially, I have "exactly", I think, the same workflow in mind. So, I am in a
path where you have been already. Thank you for sharing this Stefan.
- Computing LST images from Landsat 8.
- Instead of writing GRASS GIS native raster maps, I will switch to
GeoTIFFs via r.external.out
- After having built time series for hundreds of WRS2 Paths and Rows
combinations, I end up with some aggregated products.
- I tiled Europe in 10k^2 squares (in ETRS89) to have less tiles to deal
with. Size of images per tile is acceptable (compressed via DEFLATE, ranging
between less than 100 and up to 400MB).
- I "need" to avoid to patch these tiles in single European-wide raster
maps. Thus the need, and the idea, for a "VRT".
So, I guess the idea won't work. I will do the attempt to "learn" this
by experience.
Thank you, Nikos
* Stefan Blumentrath <Stefan.Blumentrath at nina.no> [2018-06-01 07:09:08 +0000]:
>Hi,
>Some experience with GDAL VRT and GRASS:
>Be aware of: https://trac.osgeo.org/grass/ticket/2837
>Also note also that esp. for integer rasters, compression of one big raster map can be much better than with lots of smaller tiles [1]. So I guess cases where patching by means of a virtual raster is most beneficial is in intermediate steps of an analysis chain…
>Cheers
>Stefan
>1: https://www.mail-archive.com/grass-user@lists.osgeo.org/msg33125.html
>From: grass-user <grass-user-bounces at lists.osgeo.org> On Behalf Of Markus Metz
>Sent: fredag 1. juni 2018 08:24
>To: Markus Neteler <neteler at osgeo.org>
>Cc: GRASS user list <grass-user at lists.osgeo.org>
>Subject: Re: [GRASS-user] GRASS GIS virtual raster data sets
>On Thu, May 31, 2018 at 10:41 PM, Markus Neteler <neteler at osgeo.org<mailto:neteler at osgeo.org>> wrote:
>> On Wed, May 30, 2018 at 4:21 PM, Nikos Alexandris
>> <nik at nikosalexandris.net<mailto:nik at nikosalexandris.net>> wrote:
>> > Dears,
>> > I guess there is no GRASS GIS built-in implementation of GDAL's VRT
>> > concept (several related ideas listed
>> > https://trac.osgeo.org/grass/wiki/Grass8Planning).
>> I wish to see that as well (and discussed it a while ago with our dear
>> Markus M...
>I have an idea about how to implement native GRASS VRT, but no resources to do so...
>> GRASS GIS would gain a lot having the possibility to virtually mosaik
>> raster tiles.
>> > Once past some compilation issues, I am about to try to build a VRT
>> > based on native GRASS GIS raster maps (using GDAL with support for GRASS
>> > GIS raster data), then link to this VRT via `r.external` from inside a
>> > regular Mapset.
>> Interesting, will that not cause loop dependencies?
>> I thought of true internal support for that to avoid loops.
>> > As a side-note, an image without pre-computed statistics stored in its
>> > metadata, will require some time for `r.external` to work. The latter
>> > likely forces this computation.
>> > Perhaps it is faster to use `gdalinfo`'s '-stats' option to do this.
>It will not be faster because you would need gdalinfo -mm -stats in order to get the actual values, not an approximation. Sometimes an approximation of the stats based on a subsample is stored in the metadata of a raster.
>> > I wonder if there are smart ways to build, in GRASS GIS' data base,
>> > a larger virtual raster map out of many smaller ones, without the need
>> > to actually patch the latter ones in a new raster map file.
>> I guess that some C code needs to be touched in lib/raster/ to allow
>> for a VRT-style raster concept.
>Yes.
>> Maybe we missed the current GSoC train for this idea :)>
>The tricky part is to get a qualified student for this project.
>Markus M
>> markusN
>> grass-user mailing list
>> grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/grass-user
Nikos Alexandris | Remote Sensing & Geomatics
GPG Key Fingerprint 6F9D4506F3CA28380974D31A9053534B693C4FB3
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180601/104f6027/attachment.sig>
