[GRASS-user] v.class.mlR Error
Moritz Lennert
mlennert at club.worldonline.be
Thu Jun 7 06:44:34 PDT 2018
Thanks
On 07/06/18 15:17, Jamille Haarloo wrote:
> The first 20+ lines of Stats_Training_Ben_test:
> cat,area,perimeter,compact_circle,compact_square,fd,WV_Benatimofo_1_min,WV_Benatimofo_1_max,WV_Benatimofo_1_range,WV_Benatimofo_1_mean,WV_Benatimofo_1_stddev,WV_Benatimofo_1_variance,WV_Benatimofo_1_coeff_var,WV_Benatimofo_1_sum,WV_Benatimofo_1_first_quart,WV_Benatimofo_1_median,WV_Benatimofo_1_third_quart,WV_Benatimofo_2_min,WV_Benatimofo_2_max,WV_Benatimofo_2_range,WV_Benatimofo_2_mean,WV_Benatimofo_2_stddev,WV_Benatimofo_2_variance,WV_Benatimofo_2_coeff_var,WV_Benatimofo_2_sum,WV_Benatimofo_2_first_quart,WV_Benatimofo_2_median,WV_Benatimofo_2_third_quart,WV_Benatimofo_3_min,WV_Benatimofo_3_max,WV_Benatimofo_3_range,WV_Benatimofo_3_mean,WV_Benatimofo_3_stddev,WV_Benatimofo_3_variance,WV_Benatimofo_3_coeff_var,WV_Benatimofo_3_sum,WV_Benatimofo_3_first_quart,WV_Benatimofo_3_median,WV_Benatimofo_3_third_quart,WV_Benatimofo_4_min,WV_Benatimofo_4_max,WV_Benatimofo_4_range,WV_Benatimofo_4_mean,WV_Benatimofo_4_stddev,WV_Benatimofo_4_variance,WV_Benatimofo_4_coeff_var,WV_Benatimofo_4_sum,WV_Benatimofo_4_first_quart,WV_Benatimofo_4_median,WV_Benatimofo_4_third_quart
> 1144,3832.000000,1256.000000,5.723635,0.197144,1.729624,13,76,63,46.4097077244259,9.98454911351384,99.69122100017,21.5139237092391,177842,40,47,53,40,138,98,90.2687891440501,15.2500825418009,232.565017531741,16.8940812061464,345910,81,92,100,15,61,46,40.8582985386221,7.82663897784868,61.2562776895802,19.1555675536767,156569,36,42,47,28,124,96,68.4253653444676,13.5774536655369,184.347248039801,19.8427200164517,262206,59,68,77
> 1145,12092.000000,2282.000000,5.854120,0.192750,1.645226,13,94,81,51.386288455177,10.5294376761475,110.869057775874,20.4907534532914,621363,45,52,59,21,220,199,114.230731061859,23.3590328249442,545.644414516822,20.4489917973953,1381278,101,114,128,7,76,69,46.4219318557724,8.42747122371732,71.0222712265835,18.1540726264915,561334,42,48,52,17,198,181,97.2732385047966,22.492313569247,505.904169697333,23.1228176577445,1176228,84,97,110
> All the lines of the output of v.db.select Training_Ben2 at haarlooj_Ben_Test:
> cat|id|Type|code
> 1|4|B29|18
> 2|5|B31|19
> 3|3|B28|17
Again a lack of clear documentation on my side: both the training and
the segment info should contain the same attributes, with only
additional one column ('code' in your case) present in the training data.
It should be possible to do this differently, i.e. provide the module
with the features of all segments, and only the id/cat of each training
segment with the relevant class and have the module merge the two, but
this is not implemented, yet.
I also just notice that you have the word 'Training' in both names.
The segment_file/segment_map contains the info (cat + all feature
variables) of all segments you wish to classify, either in the form of a
csv file or in the form of a vector map with the info in the attribute
table.
The training_file/training_map contains the info (cat + all feature
variables + class) of the training data. Often this is an extract of the
former, but not necessarily.
All columns in the training file have to be present in the segment file,
except for the class column (your 'code').
Sorry for the lack of docs. This module has mostly been used internally
here and so we are not always aware of the unclear and missing parts.
Having your feedback has been very useful !
Moritz
