[GRASS-user] rshepard at appl-ecosys.com sent you a file
    Rich Shepard
    Sun Jun 10 15:35:38 PDT 2018
On Mon, 11 Jun 2018, Markus Neteler wrote:
> When using gdalinfo, it does not recognize the SRS (on my system at least).
Markus,
   I get the same report with the unknown SRS.
> However, I discovered the SRS in the included XML file:
> grep SRS bh45122c3.aux.xml
> <SRS>PROJCS["NAD_1983_2011_Oregon_Statewide_Lambert_Feet_Intl",GEOGCS["GCS_NAD_1983_2011",DATUM["D_NAD_1983_2011",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["false_easting",1312335.958005249],PARAMETER["false_northing",0.0],PARAMETER["central_meridian",-120.5],PARAMETER["standard_parallel_1",43.0],PARAMETER["standard_parallel_2",45.5],PARAMETER["latitude_of_origin",41.75],UNIT["Foot",0.3048]]</SRS>
   I saw that when I looked at that file but had (still have) no idea what to
do with it.
> Apparently the SRS lookup mechanism fails in GDAL? GRASS GIS mostly
> relies on it.
> I have GDAL 2.2.4, released 2018/03/19, does anyone have a more recent
> version and could try?
   Version gdal-2.3.0 is installed here on Slackware-14.2.
   Any suggestions on resolving the problem you and I (at least, but not
Micha) have with this? I'll be more than happy to test any patches.
Best regards,
Rich
