[GRASS-user] d.rast.edit - edits not saved
Heidi Trimmel
heidelinde.trimmel at boku.ac.at
Sun Jun 10 23:11:22 PDT 2018
Dear Grass-users,
I have problems using d.rast.edit. In the archived mails I only found
that there is a problem using NULL values (*). I cannot save my edits
regardless which values I enter.
I tried using the command line, the GUI, having the rasters I edit in
the display and not having it in the display - without any effect. I am
not using aspect maps.
I installed the latest grass version last week (win7,64bit).
Could anyone give me a hint what else I could try?
Heidi
On 2018-06-11 00:35, Rich Shepard wrote:
> On Mon, 11 Jun 2018, Markus Neteler wrote:
>> When using gdalinfo, it does not recognize the SRS (on my system at
>> least).
> Markus,
> I get the same report with the unknown SRS.
>> However, I discovered the SRS in the included XML file:
>> grep SRS bh45122c3.aux.xml
>> <SRS>PROJCS["NAD_1983_2011_Oregon_Statewide_Lambert_Feet_Intl",GEOGCS["GCS_NAD_1983_2011",DATUM["D_NAD_1983_2011",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["false_easting",1312335.958005249],PARAMETER["false_northing",0.0],PARAMETER["central_meridian",-120.5],PARAMETER["standard_parallel_1",43.0],PARAMETER["standard_parallel_2",45.5],PARAMETER["latitude_of_origin",41.75],UNIT["Foot",0.3048]]</SRS>
> I saw that when I looked at that file but had (still have) no idea
> what to
> do with it.
>> Apparently the SRS lookup mechanism fails in GDAL? GRASS GIS mostly
>> relies on it.
>> I have GDAL 2.2.4, released 2018/03/19, does anyone have a more recent
>> version and could try?
> Version gdal-2.3.0 is installed here on Slackware-14.2.
> Any suggestions on resolving the problem you and I (at least, but not
> Micha) have with this? I'll be more than happy to test any patches.
> Best regards,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
