[GRASS-user] 3D raster color coding
Francois Chartier
fra.chartier at gmail.com
Mon Jun 11 19:29:04 PDT 2018
I have pasted below the colors files for the 3d raster. The data is
there as i am viewing the wireframe around the data. the r3.color is set
to bgyr. therefore, i do not see how come the interpolated data does not
show up in the display. any ideas?
r3.colors map=BHALL_May24v2 at Toronto color=bgyr
Color table for raster3d map <BHALL_May24v2 at Toronto> set to 'bgyr'
color table - the data is associated with a color as per below.
% -8.9909944534301758 33.892620086669922
-8.9909944534301758:0:191:191 -0.41427154541015626:0:255:0
-0.41427154541015626:0:255:0 8.1624513626098629:255:255:0
16.739174270629881:255:127:0 25.315897178649902:191:127:63
25.315897178649902:191:127:63 33.892620086669922:200
8.1624513626098629:255:255:0 16.739174270629881:255:127:0
Metadata of 3d raster. - same range of data as color table.
Le dim. 10 juin 2018 à 15:57, Francois Chartier <fra.chartier at gmail.com> a
écrit :
> the vector is visible in 3d as per attached screen shot. could this be a
> problem due to computer instead of Grass. there may be too many data
> points to show?
> Le dim. 10 juin 2018 à 15:46, Francois Chartier <fra.chartier at gmail.com>
> a écrit :
>> I have pasted below the colors files for the 3d raster. the screen
>> capture shows that the data is there as i am showing the wireframe around
>> the data. the r3.color is set to bgyr. therefore, i do not see how come
>> the interpolated data does not show up in the display.
>> ype of Map: raster_3d Number of Categories: 0 |
>> | Data Type: FCELL
>> | Rows: 90
>> | Columns: 85
>> | Depths: 307
>> | Total Cells: 2348550
>> | Total size: 3180868 Bytes
>> | Number of tiles: 336
>> | Mean tile size: 9466 Bytes
>> | Tile size in memory: 30420 Bytes
>> | Number of tiles in x, y and z: 6, 7, 8
>> | Dimension of a tile in x, y, z: 15, 13, 39
>> | Projection: UTM (zone 17)
>> | N: 4870795 S: 4825715 Res: 500.88888889
>> | E: 651669 W: 609204 Res: 499.58823529
>> | T: 352 B: 45 Res: 1
>> | Range of data: min = -8.99099445 max = 33.89262009
>> | Data Source:
>> | Data Description:
>> | generated by v.vol.rst
>> | Comments:
>> | v.vol.rst input="BHMat1All_May12 at Toronto" wcolumn="cat"
>> tension=40. \ |
>> | smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=2 wscale=1.0
>> zscale=1.\ |
>> | 0 elevation="BHALL_May24v2"
>> Le sam. 2 juin 2018 à 15:37, Helmut Kudrnovsky <hellik at web.de> a écrit :
>>> >Unfortunately in the Display window nothing shows up, whether in 2D or
>>> in 3D
>>> view. I do not know what i >am doing incorrectly.
>>> see https://trac.osgeo.org/grass/ticket/3571
>>> please add your findings there.
>>> best regards
>>> Helmut
>>> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180611/39315e49/attachment-0001.html>
