[GRASS-user] 3D raster color coding
Anna Petrášová
kratochanna at gmail.com
Tue Jun 12 07:28:52 PDT 2018
I sent you some time ago a video how to view 3D rasters using isosurfaces
or slices:
https://youtu.be/CmK-fEyf2SY
If you haven't added any isosurface or slice, you won't see anything beside
the 3D box.
Also, I recommend setting higher z-exaggeration.
Anna
On Mon, Jun 11, 2018 at 10:29 PM Francois Chartier <fra.chartier at gmail.com>
wrote:
> I have pasted below the colors files for the 3d raster. The data is
> there as i am viewing the wireframe around the data. the r3.color is set
> to bgyr. therefore, i do not see how come the interpolated data does not
> show up in the display. any ideas?
> r3.colors map=BHALL_May24v2 at Toronto color=bgyr
> Color table for raster3d map <BHALL_May24v2 at Toronto> set to 'bgyr'
> color table - the data is associated with a color as per below.
> % -8.9909944534301758 33.892620086669922
> -8.9909944534301758:0:191:191 -0.41427154541015626:0:255:0
> -0.41427154541015626:0:255:0 8.1624513626098629:255:255:0
> 16.739174270629881:255:127:0 25.315897178649902:191:127:63
> 25.315897178649902:191:127:63 33.892620086669922:200
> 8.1624513626098629:255:255:0 16.739174270629881:255:127:0
> Metadata of 3d raster. - same range of data as color table.
> Le dim. 10 juin 2018 à 15:57, Francois Chartier <fra.chartier at gmail.com>
> a écrit :
>> the vector is visible in 3d as per attached screen shot. could this be a
>> problem due to computer instead of Grass. there may be too many data
>> points to show?
>> Le dim. 10 juin 2018 à 15:46, Francois Chartier <fra.chartier at gmail.com>
>> a écrit :
>>> I have pasted below the colors files for the 3d raster. the screen
>>> capture shows that the data is there as i am showing the wireframe around
>>> the data. the r3.color is set to bgyr. therefore, i do not see how come
>>> the interpolated data does not show up in the display.
>>> ype of Map: raster_3d Number of Categories: 0 |
>>> | Data Type: FCELL
>>> | Rows: 90
>>> | Columns: 85
>>> | Depths: 307
>>> | Total Cells: 2348550
>>> | Total size: 3180868 Bytes
>>> | Number of tiles: 336
>>> | Mean tile size: 9466 Bytes
>>> | Tile size in memory: 30420 Bytes
>>> | Number of tiles in x, y and z: 6, 7, 8
>>> | Dimension of a tile in x, y, z: 15, 13, 39
>>> | Projection: UTM (zone 17)
>>> | N: 4870795 S: 4825715 Res: 500.88888889
>>> | E: 651669 W: 609204 Res: 499.58823529
>>> | T: 352 B: 45 Res: 1
>>> | Range of data: min = -8.99099445 max = 33.89262009
>>> | Data Source:
>>> | Data Description:
>>> | generated by v.vol.rst
>>> | Comments:
>>> | v.vol.rst input="BHMat1All_May12 at Toronto" wcolumn="cat"
>>> tension=40. \ |
>>> | smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=2 wscale=1.0
>>> zscale=1.\ |
>>> | 0 elevation="BHALL_May24v2"
>>> Le sam. 2 juin 2018 à 15:37, Helmut Kudrnovsky <hellik at web.de> a écrit :
>>>> >Unfortunately in the Display window nothing shows up, whether in 2D or
>>>> in 3D
>>>> view. I do not know what i >am doing incorrectly.
>>>> see https://trac.osgeo.org/grass/ticket/3571
>>>> please add your findings there.
>>>> best regards
>>>> Helmut
>>>> Sent from:
>>>> http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180612/81c1c460/attachment.html>
