[GRASS-user] 3D raster color coding
Francois Chartier fra.chartier at gmail.com
Tue Jun 12 18:55:00 PDT 2018
that worked! thank you. i can see the data using 3D view, in data tab,
select 3d raster at bottom (scroll down), select 3d raster, draw: slices,
shading flat, resolution 1, select wire box.
then i can add slices.  I havent mastered the system yet but i think i am
on the right track now.  thank you very much!
Le mar. 12 juin 2018 à 10:29, Anna Petrášová <kratochanna at gmail.com> a
écrit :
> I sent you some time ago a video how to view 3D rasters using isosurfaces
> or slices:
> https://youtu.be/CmK-fEyf2SY
> If you haven't added any isosurface or slice, you won't see anything
> beside the 3D box.
> Also, I recommend setting higher z-exaggeration.
> Anna
> On Mon, Jun 11, 2018 at 10:29 PM Francois Chartier <fra.chartier at gmail.com>
> wrote:
>>  I have pasted below the colors files for the 3d raster.  The data is
>> there as i am viewing the wireframe around the data.  the r3.color is set
>> to bgyr.  therefore, i do not see how come the interpolated data does not
>> show up in the display.  any ideas?
>> r3.colors map=BHALL_May24v2 at Toronto color=bgyr
>> Color table for raster3d map <BHALL_May24v2 at Toronto> set to 'bgyr'
>> color table - the data is associated with a color as per below.
>> % -8.9909944534301758 33.892620086669922
>> -8.9909944534301758:0:191:191 -0.41427154541015626:0:255:0
>> -0.41427154541015626:0:255:0 8.1624513626098629:255:255:0
>> 16.739174270629881:255:127:0 25.315897178649902:191:127:63
>> 25.315897178649902:191:127:63 33.892620086669922:200
>> 8.1624513626098629:255:255:0 16.739174270629881:255:127:0
>> Metadata of 3d raster. - same range of data as color table.
>> Le dim. 10 juin 2018 à 15:57, Francois Chartier <fra.chartier at gmail.com>
>> a écrit :
>>> the vector is visible in 3d as per attached screen shot.  could this be
>>> a problem due to computer instead of Grass.  there may be too many data
>>> points to show?
>>> Le dim. 10 juin 2018 à 15:46, Francois Chartier <fra.chartier at gmail.com>
>>> a écrit :
>>>>  I have pasted below the colors files for the 3d raster.  the screen
>>>> capture shows that the data is there as i am showing the wireframe around
>>>> the data.  the r3.color is set to bgyr.  therefore, i do not see how come
>>>> the interpolated data does not show up in the display.
>>>> ype of Map:  raster_3d            Number of Categories: 0
>>>>  |   Data Type:    FCELL
>>>>  |   Rows:         90
>>>>  |   Columns:      85
>>>>  |   Depths:       307
>>>>  |   Total Cells:  2348550
>>>>  |   Total size:           3180868 Bytes
>>>>  |   Number of tiles:      336
>>>>  |   Mean tile size:       9466 Bytes
>>>>  |   Tile size in memory:  30420 Bytes
>>>>  |   Number of tiles in x, y and  z:   6, 7, 8
>>>>  |   Dimension of a tile in x, y, z:   15, 13, 39
>>>>  |        Projection: UTM (zone 17)
>>>>  |            N:    4870795    S:    4825715   Res: 500.88888889
>>>>  |            E:     651669    W:     609204   Res: 499.58823529
>>>>  |            T:        352    B:         45   Res:     1
>>>>  |   Range of data:   min = -8.99099445 max = 33.89262009
>>>>  |   Data Source:
>>>>  |   Data Description:
>>>>  |    generated by v.vol.rst
>>>>  |   Comments:
>>>>  |    v.vol.rst input="BHMat1All_May12 at Toronto" wcolumn="cat"
>>>> tension=40. \   |
>>>>  |    smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=2 wscale=1.0
>>>> zscale=1.\   |
>>>>  |    0 elevation="BHALL_May24v2"
>>>> Le sam. 2 juin 2018 à 15:37, Helmut Kudrnovsky <hellik at web.de> a
>>>> écrit :
>>>>> >Unfortunately in the Display window nothing shows up, whether in 2D
>>>>> or in 3D
>>>>> view.  I do not know what i >am doing incorrectly.
>>>>> see https://trac.osgeo.org/grass/ticket/3571
>>>>> please add your findings there.
>>>>> best regards
>>>>> Helmut
>>>>> Sent from:
>>>>> http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> grass-user at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180612/f465a239/attachment-0001.html>
