[GRASS-user] 3D raster color coding
Francois Chartier
fra.chartier at gmail.com
Tue Jun 12 19:17:52 PDT 2018
here is a screen shot of the 3D view.
Le mar. 12 juin 2018 à 22:13, Francois Chartier <fra.chartier at gmail.com> a
écrit :
> here is a screen shot of the data set, ground surface, top bedrock, data
> points, 3d raster. still a lot of work but now i can move to the next step
> Le mar. 12 juin 2018 à 21:55, Francois Chartier <fra.chartier at gmail.com>
> a écrit :
>> that worked! thank you. i can see the data using 3D view, in data tab,
>> select 3d raster at bottom (scroll down), select 3d raster, draw: slices,
>> shading flat, resolution 1, select wire box.
>> then i can add slices. I havent mastered the system yet but i think i am
>> on the right track now. thank you very much!
>> Le mar. 12 juin 2018 à 10:29, Anna Petrášová <kratochanna at gmail.com> a
>> écrit :
>>> I sent you some time ago a video how to view 3D rasters using
>>> isosurfaces or slices:
>>> https://youtu.be/CmK-fEyf2SY
>>> If you haven't added any isosurface or slice, you won't see anything
>>> beside the 3D box.
>>> Also, I recommend setting higher z-exaggeration.
>>> Anna
>>> On Mon, Jun 11, 2018 at 10:29 PM Francois Chartier <
>>> fra.chartier at gmail.com> wrote:
>>>> I have pasted below the colors files for the 3d raster. The data is
>>>> there as i am viewing the wireframe around the data. the r3.color is set
>>>> to bgyr. therefore, i do not see how come the interpolated data does not
>>>> show up in the display. any ideas?
>>>> r3.colors map=BHALL_May24v2 at Toronto color=bgyr
>>>> Color table for raster3d map <BHALL_May24v2 at Toronto> set to 'bgyr'
>>>> color table - the data is associated with a color as per below.
>>>> % -8.9909944534301758 33.892620086669922
>>>> -8.9909944534301758:0:191:191 -0.41427154541015626:0:255:0
>>>> -0.41427154541015626:0:255:0 8.1624513626098629:255:255:0
>>>> 16.739174270629881:255:127:0 25.315897178649902:191:127:63
>>>> 25.315897178649902:191:127:63 33.892620086669922:200
>>>> 8.1624513626098629:255:255:0 16.739174270629881:255:127:0
>>>> Metadata of 3d raster. - same range of data as color table.
>>>> Le dim. 10 juin 2018 à 15:57, Francois Chartier <fra.chartier at gmail.com>
>>>> a écrit :
>>>>> the vector is visible in 3d as per attached screen shot. could this
>>>>> be a problem due to computer instead of Grass. there may be too many data
>>>>> points to show?
>>>>> Le dim. 10 juin 2018 à 15:46, Francois Chartier <
>>>>> fra.chartier at gmail.com> a écrit :
>>>>>> I have pasted below the colors files for the 3d raster. the screen
>>>>>> capture shows that the data is there as i am showing the wireframe around
>>>>>> the data. the r3.color is set to bgyr. therefore, i do not see how come
>>>>>> the interpolated data does not show up in the display.
>>>>>> ype of Map: raster_3d Number of Categories: 0
>>>>>> | Data Type: FCELL
>>>>>> | Rows: 90
>>>>>> | Columns: 85
>>>>>> | Depths: 307
>>>>>> | Total Cells: 2348550
>>>>>> | Total size: 3180868 Bytes
>>>>>> | Number of tiles: 336
>>>>>> | Mean tile size: 9466 Bytes
>>>>>> | Tile size in memory: 30420 Bytes
>>>>>> | Number of tiles in x, y and z: 6, 7, 8
>>>>>> | Dimension of a tile in x, y, z: 15, 13, 39
>>>>>> | Projection: UTM (zone 17)
>>>>>> | N: 4870795 S: 4825715 Res: 500.88888889
>>>>>> | E: 651669 W: 609204 Res: 499.58823529
>>>>>> | T: 352 B: 45 Res: 1
>>>>>> | Range of data: min = -8.99099445 max = 33.89262009
>>>>>> | Data Source:
>>>>>> | Data Description:
>>>>>> | generated by v.vol.rst
>>>>>> | Comments:
>>>>>> | v.vol.rst input="BHMat1All_May12 at Toronto" wcolumn="cat"
>>>>>> tension=40. \ |
>>>>>> | smooth=0.1 segmax=50 npmin=200 npmax=700 dmin=2 wscale=1.0
>>>>>> zscale=1.\ |
>>>>>> | 0 elevation="BHALL_May24v2"
>>>>>> Le sam. 2 juin 2018 à 15:37, Helmut Kudrnovsky <hellik at web.de> a
>>>>>> écrit :
>>>>>>> >Unfortunately in the Display window nothing shows up, whether in 2D
>>>>>>> or in 3D
>>>>>>> view. I do not know what i >am doing incorrectly.
>>>>>>> see https://trac.osgeo.org/grass/ticket/3571
>>>>>>> please add your findings there.
>>>>>>> best regards
>>>>>>> Helmut
>>>>>>> Sent from:
>>>>>>> http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
>>>>>>> _______________________________________________
>>>>>>> grass-user mailing list
>>>>>>> grass-user at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180612/a4f263ba/attachment-0001.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180612/a4f263ba/attachment-0001.gif>
