[GRASS-user] g.proj fails on winGRASS trunk with AIG/Arc/Info Binary Grid input
Markus Metz markus.metz.giswork at gmail.com
Tue Jun 12 07:34:32 PDT 2018
On Tue, Jun 12, 2018 at 4:07 PM, Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> On Tue, 12 Jun 2018, Markus Metz wrote:
>> Gotcha! Valgrind gave me a hint, hopefully fixed in trunk r72802.
> Markus M,
>   Here, running 7.5svn r72804 there's no change with my data set.
as of r72802, it should be possible to create a location from the data, and
the projection check should work.
About valid values only along the edges, that's a different issue, most
probably there is nothing else in the input data. The data provider would
know if this is correct.
Markus M
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180612/446e880f/attachment.html>
